tires allignment help
Old Sep 26, 2013 | 03:29 PM
Gazika's Avatar
i've got 2 neova ad07 tires on front with inside worn out a bit , want to drive on local time attack but can't decide leave or not that worn out sides on the inside or change sides . i've got -3 degree negative camber . need some advise on which side would work better for track.
Old Sep 26, 2013 | 07:41 PM
Balrok's Avatar
Depends on a bit more info, suspension etc. If it's flat but the rest looks new then it's obvious you aren't driving hard enough on the street . With -3 you should technically be using the rest of the tire in a track situation (assuming your experienced and can push the care safely) at that point so it'll only come into play if it's raining and your going into a braking zone hard. If I remember right they're directional so you could swap back's to fronts if you want or have them flipped at your tire store. Again too general of a question.
Old Sep 26, 2013 | 11:57 PM
Gazika's Avatar
i have experience but this is my first time with megan track series coilovers installed and this tires which were already worn a bit when i got them , i just can't decide which side to use on the outside. unfortunately we don't have any tire service on track, so i have do choose my option before i get there.
i'll take some pics today.
Old Sep 27, 2013 | 07:07 AM
ratt_finkel's Avatar
Use the meatier part of the tire on the outside. Keep an eye on the bald spot. As soon as you see cords, then the tires are done. Try to keep wheel spin down to a minimum too. That includes aggressive slip angles. That should help save the tire life.
What are you running for toe?
Old Sep 27, 2013 | 07:57 AM
Raptord's Avatar
If you have adjustable camber plates, consider setting a less aggressive camber for the street and switching to to your more aggressive camber at the track. You'll need to have an alignment shop tell you how many turns of the tie rod you need to do on each side to bring your toe back where you want it. It may sound like a lot of trouble, but I've gotten to the point where it takes me about 15 minutes to go from one setting to another.
Blue8g
Midwest Region
Sep 23, 2016 09:53 AM
SophieSleeps
52
Jun 17, 2011 12:32 AM
9evolution
Jun 9, 2010 02:12 PM
FushunEvo
May 28, 2009 12:10 AM
Frank5509
Apr 12, 2009 09:53 AM
