Clunking front end noise??
Old Jun 28, 2011 | 04:40 PM
  #556
ariasdejesus's Avatar
check the struts, top hats, had the same problem
Old Aug 4, 2011 | 09:16 AM
  #557
jwick76's Avatar
Had the same issue with the clunking (and also minor leftside pull) after replacing busted ball joints and shredded end links, just brought this to a good shop to double-check alignment (which was fine when they checked it) and they told me strut mounts (cushions) and that my KYB shocks with less than 3yrs of New England weather were leaking. F-ing BS. Just ordered new Rabestos mounts and cushions and Monroe expert series shocks from Rockauto. $292 shipped. I'm so pissed I wasted money on KYB. Lesson learned.
Old Nov 7, 2011 | 05:31 PM
  #558
pitbulllove2003's Avatar
cherck the hat bearing nut at the top of the strut / coilover i have had the same noise often and i live on a nasty dirt road and thats generally what mine is is that nut likes to come lose
Old Nov 7, 2011 | 07:24 PM
  #559
Thoe99's Avatar
Same here. I fixed mine by tightening this top strut nut.
Old Nov 12, 2011 | 09:22 PM
  #560
jwick76's Avatar
also found that my springs are shot and are loose...so investing in some coilovers. They clunk whenever I turn or hit any road crap.
Old Jul 6, 2012 | 11:52 PM
  #561
Peter1's Avatar
EVO 8 front end clunking RESULT!
I have a Evo 8 RHD JDM with the same front end clunking noise as everyone else (Stock suspension).
The noise turned out to be the sway bar moving sideways (towards the drivers side only) when the wheel was pointing right and hitting the subframe. New bushes fixed the problem
NOTE: I noticed Whiteline suspension sway bars have an oversized sleeve to prevent this happening
Old Jul 8, 2012 | 05:34 PM
  #562
Smelli Bugatti's Avatar
I had the "klunk" not to loud and not too many times
Old Jul 8, 2012 | 07:41 PM
  #563
stihlalive's Avatar
its the strut mount, im 99% sure of it. i have mine ordered and on the way! honestly tho it should mean time for coilovers for all of us lol
Old Jul 9, 2012 | 10:38 AM
  #564
elim0's Avatar
I have the same clunking noise and a JDM evo8. which bushes are you referring too ? i have replaced my swaybar bushes but the noise still remains :S ??
Old Jul 9, 2012 | 06:44 PM
  #565
Peter1's Avatar
The bushes are the "D" shaped ones that go around the sway bar and bolt to the chassis. I have since been advised to add the "lateral locks" as apparently evos are known to have the sway bar move enough to hit the sub frame. You can check this by taking off the left hand front wheel and pushing the sway bar. If it hits and makes a noise, add the lateral locks. Hope this helps
Old Jul 10, 2012 | 05:26 PM
  #566
headlock's Avatar
where do you get these "lateral locks"? I dont suppose you have a part number or something for them?
Old Jul 11, 2012 | 10:40 AM
  #567
elim0's Avatar
yeah they are the bushes i have replaced. i will check it again, but let me know how your car goes with the lateral locks ? or is yours fine without them ??and yes, where to purchase from
Old Jul 12, 2012 | 03:41 PM
  #568
Evoardo IX's Avatar
I've been dealing with the clunking for years ( bilstein PSS9, got them brand new) and today I tightened the top nut and also found out those are not reusable, you have to get new ones once they come loose ( I know I know, stupid mistake on my part)
Everything seems to be good now, will report back if the noise comes back, but for now I am enjoying a clunk free ride after many headaches lol
Old Jul 12, 2012 | 11:13 PM
  #569
elim0's Avatar
Hey evoardo ! i have pss9s too. what exactly did you do to cure the clunking/knocking problem ? is it the shock ?? or other components ie. bushes/end links/ ball joint / etc ??
let me know please ! much appreciated !!
Old Jul 13, 2012 | 07:10 AM
  #570
Evoardo IX's Avatar
What exactly is your problem? I had a slight clunk I could feel in the pedals, it was only at slow speed or over small bumps. To rule the strut out, I sent it to Bilstein and they serviced the strut, I got it back brand new but the noise was there. To rule out any other problem with the car, I installed stock suspension in the front and the noise was gone, so I knew it was the PSS9 somehow. The problem is I reused the top nuts when I installed new top hats, and you are supposed to get new top nuts, make sure you get them there tight, and you should be good ( assuming you did all the "tests" I did to make absolute sure it's the coilover that's clunking )
