Lower control arm boot is torn. Replacement question....
Old Oct 13, 2010 | 04:00 PM
binh's Avatar
I have a low mileage car and my ball joint but the boot is torn from someone who previously worked on my car.
Can you get a new rubber boot for the ball joint from the dealer?
Does anyone know how to remove the old boot and put the new one on? Does the joint need to be pressed out?
I was playing with it a little today it doesn't seem as if the rubber boot just slides off.
Old Oct 13, 2010 | 04:33 PM
Murf's Avatar
yes you can order just the boot. I had to do that not long ago. But I found my robispec ball joints and put those in.
Old Oct 13, 2010 | 04:48 PM
binh's Avatar
Do you have any idea how to replace the boot?
Old Oct 13, 2010 | 05:16 PM
delongedoug's Avatar
https://www.evolutionm.net/forums/ev...hop-press.html
Old Oct 13, 2010 | 05:32 PM
binh's Avatar
Thanks.
It appears that the boot simply slides over the ball joint edge. Hmm, I guess I'll just try that.
Old Oct 15, 2010 | 01:11 PM
letMeIn's Avatar
you can remove old boot with a small flat head screwdriver, just pray it from 1 side first and then from left and right until its off. Clean old grease with a towel, apply new grease to the ball joint and inside of the new boot. Slide the new boot on, and gently tap from each side until it is seated. U may also use a round Socket and tap it gently to get the boot on. Very easy job to do.
Old May 4, 2013 | 03:36 PM
a4rontran's Avatar
^^^do you know the part number for this boot? i just found the boot is ripped.
Thanks
Old Mar 30, 2014 | 01:17 PM
ekizenbe's Avatar
anyone have the boot part number?
Old Mar 30, 2014 | 01:34 PM
deylag's Avatar
I think the part number is MB808555.
I got it from here.
http://www.streettunedmotorsports.co...r_mb808555.htm
Live4Redline
27
Apr 14, 2018 04:13 PM
jingalalahoe
Sep 9, 2016 12:44 AM
MisUnderStood
20
Feb 19, 2016 04:10 PM
EVOlutionary
Mar 9, 2014 10:12 AM
ProPilot04
May 17, 2013 10:55 AM
