Replaced front wheel bearing....still has bad noise
Old May 28, 2015, 08:43 AM
vr4gasmtt's Avatar
IS replacing the front wheel bearing difficult? I know there is a writeup, but skimming through it, it does not look easy.
Old May 28, 2015, 12:00 PM
barneyb's Avatar
I did one recently and chose to remove the knuckle so that I could take the hub containing knuckle to a shop with a press. I find it humorous that the most difficult part of the job was removing the plastic fender liner to get to the ABS sensor plug. The wheel sensor is not usually removalable by the time the car has enough miles to require a bearing.
Old May 28, 2015, 01:32 PM
Terror Rising's Avatar
As long as your parts aren't super rusty it's a cake job. I did my last one in 20 minutes but, to be fair, the car was already on jack stands and it's a garage kept Texas car.
Old May 28, 2015, 09:04 PM
barneyb's Avatar
The shop said mine was pretty stuck and coming from them, they work on 18 wheelers, was enough to make me happy it took it to them. My car is at a 100K and I live where there is winter. It was $15 to get the hub punched out.
Old May 29, 2015, 06:57 AM
heel2toe's Avatar
Lol yeah I had to remove both front knuckles and removing that friggin clip was the worst part between the stupid fender liner clips and then getting the clip to seperate from the inner fender well.
Always so jealous of you guys from TX, FL CA and wherever else rust is uncommon. The reality is that its such a simple job, remove wheel, remove caliper then rotor pop off axle nut remove 4 bolts holding on bearing assembly and throw it back together.
Unfortunately all 4 of mine were seized so off came the knuckle and my HF shop press to the rescue! This of course added significant time to the whole process.
Oh yeah my car has seen salt unfortunately and I can attest to them being all seized up in there. If you don't have access to a shop press, if seized finding someone with one to separate it is a must.
Old May 29, 2015, 07:50 PM
I'm from northeastern NY. I once spent 6+ hours on a wheel bearing on my DSM. I always knew southern cars were rust free but after living here and buying one it's amazing. I don't even own PB Blaster anymore.
Old Jun 2, 2015, 09:57 PM
Dave123456789's Avatar
When you do wheel bearings its wise to do both sides regardless. the other will fail soon.
Only time a wheel bearing is hard is when you have driven it while ****ed for ages and its welding to the stud axle
Old Oct 22, 2015, 07:58 PM
rebeljeep's Avatar
I just replaced a driver side bearing. Did not fix the slight thumping, whirling sound while driving. I dread doing the other side because of the retaining clip is to so difficult to reinsert. I don't think it's the bearings. I'm thinking about just driving it until it get so bad that I can finally discover what it is.
Evo_8_power
May 23, 2017 08:28 PM
Lancerfry30
Nov 14, 2016 11:25 PM
Evo'lusive
May 11, 2016 03:59 AM
Lancerfry30
Feb 28, 2016 02:45 PM
Sheasta
Feb 6, 2016 08:29 AM
Quick Reply: Replaced front wheel bearing....still has bad noise
