Cant remove strut top nut
pull the bump stop down, clamp a vice grip on the shaft as high as you can (has to be above where the bump stop goes or you will wreck the seal!) and zap with an impact. if there is no room for a vice grip, use a rubber strap wrench anywhere along the shaft, it wont hurt it.
if you cant get to the shaft with a vice grip, *carefully* melt or heat up the nylon part of the nut and get it out of the way, no nylon=much less chance of it spinning.
Rom
Sep 15, 2014 10:43 AM
ezzey
Jun 5, 2014 05:48 PM
adrock1559
Evo X How Tos / Installations
Jun 12, 2008 02:43 PM
belizelittle39439
41
Jan 14, 2008 09:29 AM
