nsf knocking
Old Nov 7, 2010 | 06:09 AM
tuftyporkpye's Avatar
nsf knocking
hi there
recently bought an evo 8,
just wondered if anyone has had a problem with a knocking from which i belive is coming from the front nearside somewhere,is not very loud,can be heard when turning right at low speed on uneven ground
have changed droplinks and the wheel bearing,when the bearing was changed it went away and i thought id sorted it however after 300 miles its back ,ive been to a couple of garages but they cant source the problem
as i say its not very loud just very annoying
other than that ,i think its a fantastic car
Old Nov 7, 2010 | 06:23 AM
delongedoug's Avatar
CV joint is usually the first suspect on a front end rotational clunking sound while turning.
Old Nov 7, 2010 | 06:30 AM
the garage says its not the cv joint
i suppose the right decription of the sound is a light rattle
ive had most of it in bits down there and all looks fine
i find it quite hard to replicate the sound when its on axel stands
thanks for your reply much appreciated
Old Dec 28, 2010 | 09:20 AM
ruta's Avatar
Jack one side of the front up first and where you see the strut spray some wd40 onto the the strut piston THE SHINNY PART repeat on the other side if there is still knocking after that then it is either the droplinks or top mounts check the top mounts but 90% of the time it is usually a sticking strut but i am 100% sure the WD40 will free it a common problem over the pond in england due to the rain water working its way into the strut a permant fix would be to strip the strut down and regrease
Old Dec 28, 2010 | 11:09 AM
ODUB's Avatar
If I had to guess, I'd say it's the top mounts. very common problem that I have myself
Old Dec 28, 2010 | 07:01 PM
TommiM's Avatar
The clunking sound you say happenning on uneven ground when turning sounds eerily similar to the rear diff, which is common especially if you have a TRE maxx lock rear diff or similar. Have you tried putting in some friction modifier in the rear diff to see if that goes away? It might sound like its coming from the front, but it could just be echoing underneath and making it seem that way, idk. It might be worth a try, its only a few bucks for some redline lsd friction modifier.
jbuhrman
28
May 2, 2016 12:08 PM
MX750CAL
Lancer Troubleshooting
Feb 20, 2016 04:06 AM
A_Rawww
15
Jan 28, 2013 06:08 PM
sega_yaj
Jun 26, 2009 01:33 PM
GinNBoost
Oct 19, 2008 09:50 AM
