Just found some Hancook RS3 235/45/17's
City Tire in Los Angeles has them. I just picked up my set last night. I have been trying to track down this size tire and have not had any luck. I finally reached out to Hancook USA and they sent me to that shop. I will snap some pics tonight. But first impressions are great. My brother drove my car and said on the street they are compareable to his t1r's. Will hit the track soon.
The tires do not run wide.
I went with a 235 because, ROBISpec said I should run the 235 on my stock rim. I asked about the 255 and he said it was just way to wide. He told me why but I cannot remember for the life of me now.
Tires were 600 installed.
The 235's just came out, they are listed on the website however I had to call hancook directly to find out where I coudl get them.
Can anyone else comment on this?
riceball - what was happening why you hated running the 255's?
Hankook recommends at least an 8.5" wheel width for the 255/40 R-s3 for a reason. If you run an 8" wide wheel, then yes you'll increase the contact patch, but you'll also get some negatives like a reduction in shoulder stiffness, which leads to more tire roll over on hard cornering, and reduced responsiveness. So...buyer beware.
For every width of tire, there is recommended width of rim. 255 are designed to run on 9" width wheel in order to fully take the advantage of 255 width.
If you run 255 on a 8" wheel, it will result in taller diameter (taller tire height=softer side wall) because there is not enough room (width) for the tire, therefore your tires will not have the same amount of patch contact as on a 9" wheel.
Again this is common knowledge.
