What offset for 15" rims.
Old May 8, 2011 | 06:37 PM
canitbethislong's Avatar
Anybody run 15" rims on their evo with stock brakes? If so what offset or what size spacers are you running if they are needed. I tried searching and google searching couldnt find anything thanks guys.
Old May 9, 2011 | 07:25 AM
SpeedAddict502's Avatar
Just curious what are you wanting 15" wheels for? Rallying? I would be pretty surprised if 15 inchers clear the front brakes.
Old May 9, 2011 | 07:52 AM
Boltz.'s Avatar
FCOTM Winner
You're not clearing the stock brakes with 15's. Period.
Old May 9, 2011 | 07:55 AM
No not rallying, drag.
Cool if they dont clear thats what I was wanting to know. I guess it will be 17's for a while then. Unless someone has a recipe for 16's
Old May 9, 2011 | 08:13 AM
Smike's Avatar
https://www.evolutionm.net/forums/ev...eded-help.html
Old May 9, 2011 | 08:29 AM
Thanks.
Out of curiosity what offset is needed on 16" rims then? If I cant find some rx7 wheels then maybe I will go another route.
Old May 9, 2011 | 09:09 AM
Boltz.'s Avatar
FCOTM Winner
All depends on spoke clearance in the front. For all other reference use a wheel offset calculator. The one from 1010 tires is my favorite. Stock wheel offset is 38mm on a 8" wheel.
RX7 wheels are 50mm and use 20mm spacer in front so 50mm r, 30mm f.
GL
Old May 9, 2011 | 09:21 AM
So If I got some 45 offset rota slips then I would need a 15mm spacer in the front? I mean I dont want to get some tires on not be able to use them at all is basically what Im trying to eliminate.
Old May 9, 2011 | 12:33 PM
Boltz.'s Avatar
FCOTM Winner
You should really do some research on offset. Use the calculator I told you about. Offset is a dependent variable on width. Also, like I already said, spoke design plays into clearing the front calipers. You could have two wheels with the same width and offset and one could fit and another might not.
Tek1999
Apr 3, 2015 03:49 AM
5 ltr. beater
Jan 30, 2011 04:04 PM
LancerOZ Boy
10
Sep 17, 2009 01:06 PM
ynotlim
04-06 Lancer Ralliart How To Requests / Questions / Tips
Jul 31, 2008 09:31 AM
M3this
Jan 18, 2006 09:38 AM
