hoosier r6 on stock se rims?
I am looking to get some new tires to mount on my spare set of stock se bbs's. I will only be using them when racing which is mainly drag but i would also like to try a few hpde. I was looking for competion tire not a street tire but dont want a full slick so i was looking at the hoosier r6 dot. I want to know if it would fit the rim without any clearance issues with the suspension or the fender. I have the MR shocks with swift springs. thanks for any input
Any tire will fit....just depends on the size.... generally the biggest you can go on a stock rim without bulging is 245/40/17 but you can get a 255 on there
now with that said dont' get that tire for your suspension set up, I have Re valved bilsteins with springs and that's too soft for NT01's already...I can only see it getting much much worse with a stickier tire.
255/40/17
or
245/45/17
on the stock bbs's
i was looking at the 245/45 17. i went to track with the rims i have on now at was going thru the traps at 8k and was only trapping 114. i figure if i get a taller tire it will bring my revs down and help my mph.
By too soft u mean it would compress too much because of the extra traction? What would you suggest for my set up?
323 whp on TT dynojet is about right for 115-116 mph.
Truth is - pick one area to race in. You want to drag -- R6s are not drag tires (no road racing tire is). Get drag radials.
If you want to do DE towards TT -- start on good extreme summer tires. Then progress to r-comps.
The R6 won't be the best drag option as it's sidewalls are not designed to give under launch. As a result you won't have the wide flat footprint desired for launching at the line. By the same measure you don't want a drag radial for auto-x or road events as their walls are too soft/are not built for cornering. To do it properly you should should have a set of each.
Fitment wise that depends on the size. I've seen many run 245/40-17 and 245/45-17 with no issues.
xenonk
Mid-Atlantic Region
Apr 5, 2008 08:43 AM
EVOQUICK
Oct 26, 2004 12:10 PM
