biggest spacer
Old Jul 9, 2011 | 01:14 PM
loneracer05's Avatar
biggest spacer
whats the biggest i can safely space my rims on an evo ix? rubbing is not an issue cuz its in the works of the widewody kit.i need to space the rims out for mock up on the rear quaters.money is tight for the ccw rims i want to get so i need to make due.also where can i get a large spacer and extended studs?
Old Jul 9, 2011 | 01:20 PM
Boltz.'s Avatar
FCOTM Winner
What are you proposing? Running stock wheels with a widebody?
Or are you doing this so you know what wheels you can fit? CCW will work with you to make sure you get the proper wheels so if that's the case, don't worry about a spacer.
Also, if you aren't going to be driving the car you can make a mock spacer out of wood.
Biggest I've seen is 25mm ~1in
What widebody do you have?
Old Jul 9, 2011 | 07:13 PM
Im mocking the car so I know where to trim the rear quarters to fit the ccw rims. I know they will make my rim to fit.but I need to trim the car 1st.the rear is do luck...the entire kit is a mishmosh of jdm
Old Jul 9, 2011 | 09:26 PM
BenJ's Avatar
Go to motorsports-tech.com for your spacers. I run a custom 26mm spacer from them. Google ARP wheel studs and buy. I'm running their 3" studs and could go to a 30mm spacer if absolutely necessary.
Old Jul 10, 2011 | 03:15 AM
Ok cool thanks ben
Old Jul 10, 2011 | 09:01 AM
Boltz.'s Avatar
FCOTM Winner
Are you talking about the factory rear quarters? Where to cut them? https://www.evolutionm.net/forums/ev...track-car.html
Some pics there ^
What wheel and size are you trying to fit? Buying spacers for this type of mock up is a total waste of money.
Old Jul 10, 2011 | 09:13 AM
rodent's Avatar
If you're talking about a non-bolt-on spacer, I'm almost maxed out on thread with my 22mm spacers with the ARP 3" studs.
Old Jul 10, 2011 | 04:12 PM
BenJ's Avatar
^^^lol, you can go a lot further. You need a minimum of 6 full turns and you're good.
Old Jul 11, 2011 | 06:05 AM
rodent's Avatar
Rule of thumb is a bolt or nut should be threaded a minimum of at least the same length, as the diameter of the stud or bolt. (eg. a 12mm bolt should be threaded in a minimum of 12mm or .5")
I'm guessing 6 turns equals roughly 6mm so you're about half of thread needed. I'm sure 6 turns is okay and holds but I'd be a little nervous on hard corners with sticky tires.
Old Jul 11, 2011 | 06:09 PM
BenJ's Avatar
I did not pull the number 6 out of a tophat...it was given to me by robi and he uses that rule on his own cars as well as customers. With robi's track experience, that is good enough for me.
Old Jul 12, 2011 | 01:28 PM
Dallas J's Avatar
Veteran: Army
Going by the standard Engineering rule of thumb, an M12 x 1.5 should have 1.5 times the thread Dia in thread length engagement. That puts it at 12 threads min engagement.
Of course thats a rule of thumb and doesnt really scale well with dia. So going with 1 times thread dia would leave you at 8. Thats what I'd shoot for.
Old Jul 13, 2011 | 03:26 AM
Well unfortunately new rims are a bit out of the budget for awhile so im going to need to get spacers for a bandaid fix or drive around loookn silly with my rims tucked deep in the wheel wells lol. Im going to run 18x10 I think and use a huge offset.the quaters are 35mm wider so in theory I should need a 35 mm spacer which I think would be a bolt on spacer correct?
Mrswhite-evo
Jul 28, 2015 01:44 AM
Hamman
Outlander Sport
Dec 28, 2014 05:58 AM
SpencerEvo
Oct 1, 2014 02:33 PM
201Motorsports
Evo 'For Sale' Wheels / Tires
123
Mar 31, 2011 08:58 AM
