Function & Form V2 coilover reviews?
Thanks - I really appreciate your help!
8K/8K will be more understeer prone (inability to turn) than the 8K/10K. The Whiteline rear sway bar has 3 settings (soft/med/hard)
On an 8K/8K setup, you can try setting the rear bar at the hard setting to assist w/more oversteer (tail out). On the 8K/10K setup you can try setting the bar on the soft setting.
Adding the bar is just a good idea while youre already doing the coilovers. The WL rear sway bar is almost a required upgrade when adding spring rate to the EvO IMO.
If you push the EvO hard on the streets / track, I say, get the rear bar.
We have a great group of suspension vendors. Check out this thread & call a few of them for shipped prices
https://www.evolutionm.net/forums/ev...-handling-117/
Joe
Where is a best place to purchase or inquire about the Fortune coilovers? I recently just began my research so any information you can share would be helpful. My suspension is shot and im looking for replacement. thanks
They can be found in our vendor section here:https://www.evolutionm.net/forums/ev...-here-map.html
Boost411
19
May 6, 2018 11:27 AM
FS[SouthEast]: Evo 9 coil cover
hutch959
Oct 25, 2016 06:20 AM
wingzerojm
Aug 5, 2016 06:54 AM
