Ohlins PCV problem ((
Old Nov 19, 2011 | 01:33 PM
KOOLER's Avatar
Hi,
got an issue... After car is jacked up and lowered down one coilover (front right) stays in the uppered positon. For some time or when I start driving. Then it goes to normal position with "clank" sound. Car drives OK, there are no leakage of oil from coilover and there's no damage on it.
What could it be? Is it dangerous? I'm afraid it can stay in this position during driving after going up the hill or whatever
BTW, It's Ohlins PCV for Evo IX.
Any ideas?
Thanks!
Anton
Old Nov 19, 2011 | 04:29 PM
TommiM's Avatar
sounds like the spring is binding up due to possibly not being seated correctly so it keeps moving around.
Old Nov 20, 2011 | 02:59 AM
KOOLER's Avatar
So should I remove the coil and check the spring seating?
Old Nov 20, 2011 | 06:41 AM
chu's Avatar
chu
Sounds more like the spring unseats itself and not returning to the lower perch properly when lower back to the ground. Helper springs can help with this issue. Lower the car slowly next time and guide the spring into position. I have the same Ohlins PCV and use to the same thing.
Old Nov 20, 2011 | 07:56 AM
KOOLER's Avatar
So in your case it does not return to proper position as well? What helper springs did you install to avoid the issue? Or just ignoring it?
Old Nov 20, 2011 | 07:58 AM
chrisw's Avatar
sounds like you need to get your ohlins rebuilt.
Old Nov 20, 2011 | 11:45 AM
KOOLER's Avatar
It's PCV fixed perch non-servicable model with less them 5K km on them (
Old Nov 21, 2011 | 06:32 AM
chu's Avatar
chu
I replied to this, but it seems it didn't make it through. I would just lower the car slowly, and made sure the springs seated into the perches correctly. Since then however, I've raised my fronts to full height, in light of suspension geometry, and thus the spring doesn't unseat anymore. I have only installed helper springs in the rear now, since my rear is lowered. The helpers definitely keeps the spring front being unseated and clanking around when the suspension is unloaded. Good luck.
Old Nov 21, 2011 | 06:53 AM
GTWORX.com's Avatar
Can you take some pictures? You have the non-height adjustable fixed perch struts that use OEM fitment springs?
- Andrew
Old Nov 21, 2011 | 07:02 AM
KOOLER's Avatar
Sorry bro did not get the whole idea first time. Now I see. Thank you!
Old Nov 21, 2011 | 07:05 AM
KOOLER's Avatar
Sure I'll do tomorrow!
Yes exacty! Except they come with Ohlins-Eibach springs. Here are how they look:
(are they servicable)
- Andrew
Old Nov 21, 2011 | 07:21 AM
chu's Avatar
chu
Oh dude, I actually replied to you the second time. I meant that my post didn't make it, not that you didn't understand. SORRY!
Oh, these fixed perches uses OEM style springs, and should not be unseating, or need anything I mentioned. I was thinking the PCV coilovers. You might have suspension binding as one poster suggested.
Old Nov 21, 2011 | 10:36 AM
GTWORX.com's Avatar
I would call or email Ohlins immediately and explain the problem.
- andrew
Old Nov 21, 2011 | 01:59 PM
KOOLER's Avatar
1) No problem absolutely!
2) I hope so... I'll re-mount them tomorrow to see what could be done.
Old Nov 21, 2011 | 02:00 PM
KOOLER's Avatar
Obvious but I've missed this Just wrote to Ohlins, thank you for suggestion!
- andrew
