Need help finding some wheels
Old Nov 23, 2011 | 12:56 PM
JohnBradley's Avatar
So I dont often post in the Tire and Wheel forum but I am looking for some expert help. Once upon a time I sold wheels and tires so I know who to call for the most part but I am drawing blanks on what I am after for drag wheels for next season.
I am trying to find a 35-38mm offset 15x9 wheel or at least get an opinion on these-
Centerline Fuel 15x9 et38
http://www.summitracing.com/parts/CLL-045907545/
I will not be running center caps.
I will be running these tires so a 15x9 or 15x8.5 at the tightest-
M&H 275-50-15 Bias Drag tire (not slick)
http://www.summitracing.com/parts/MNH-MSS005/
I heard there was a Rota in that size but cant find it on their site. Let me know what you guys have found that I havent or where I can look. I am trying to stay away from having a custom race wheel made as I would like to be able to drive this on the street. I suppose if I have to order a custom street wheel that might be something I can consider.
Thanks
Aaron
Old Nov 23, 2011 | 01:06 PM
Lazyfong's Avatar
5x114.3 pattern?
Old Nov 23, 2011 | 05:48 PM
yeah 5-4.5/5-114.3, normal Evo.
Old Nov 23, 2011 | 09:50 PM
gsrboi80's Avatar
Maybe a Rota Slipstream? I def have seen them in a 15" 5x114.3.
From there it would be the width and offset you need
Old Nov 24, 2011 | 10:58 AM
I thought there was a Rota. I will look again and see if I can find them.
Thanks
aaron
Old Nov 24, 2011 | 11:22 AM
Spec-Ops1's Avatar
Rota slipstreams Aaron... 15x8
This is a +40, you will need a small brake kit to run these, and will need a 20mm studless spacer if you have extended studs, or a 25mm studded spacer if you have OEM studs still on the car as the studs will extend past a 20mm spacer...
These can be hard to find in stock, however Emery@STM has a good lead on this set up if you wanna go through him...
Old Nov 24, 2011 | 12:05 PM
Need a 9" for the tires I am gonna run. Otherwise I would buy back my Centerline Convo Pro 15x8s from Luke and get E.T. Streets. I want to run the M&H since they work on the Little Auto so well, just in a more manly Evo size. If it runs 9.95 on 235-60-15s with traction issues I think the 275-50-15 will work better in a heavier car.
Thanks for the heads up Freddie.
Aaron
Old Nov 24, 2011 | 12:11 PM
RevMoto's Avatar
Rotas for a shop car? Should be a law against that. Surely you can find something lighter. How much are you looking to spend?
Old Nov 24, 2011 | 01:29 PM
Rota's are definitely not my first choice.
Its more about being able to run them on the street than anything. I have found the following that should work-
The aforementioned Centerlines
Weld Prostar 15 x9, 6.5" backspacing
TRMotorsports 15 x9 et 36 (apparently available in a 5-114.3, saw 4-100)
Weld Magnum 2.0 and 3.0 (not street friendly)
ROTA are not available in what I am after
I am willing to spend 400-450 a wheel but like I said I want to be able to drive on them. Otherwise I will probably keep my 275-40-17 RA1s on the 17x9s for the time being and worry about it when I wear them out. I suppose I could keep those for the street and then use the M&H at the track but I like the idea of it being in real street trim. I have no issue running the tires on the street I just want a wheel I am not going to bend or deform the first time I encounter some rough pavement (no matter how slow I go).
Old Nov 28, 2011 | 12:30 PM
No other ideas?
If I can get them it looks I will get the TRMotorsports for street wheels when I need the 15s and then run my 17s the rest of the time.
kingcobra10sec
Feb 24, 2017 06:29 PM
Jaraxle
Aug 13, 2016 06:50 AM
MitsuJoe
E85 / Ethanol
47
Dec 14, 2015 06:10 PM
Evokid03
For Sale - Wheels / Tires
Nov 30, 2010 01:23 PM
crypto
Lancer Engine Tech
32
Jul 19, 2006 12:29 AM
