Why carry a spare?
Normally when you change wheels and tires, you change the width and keep the diameter the same so it doesn't affect the speedometer much.
Isn't the spare the same diameter as the stock 235/45/17? Running the spare temporarily shouldn't hurt anything unless you went with a taller tire such as 245/45/17 or a taller 18" tire.
normally when you change wheels and tires, you change the width and keep the diameter the same so it doesn't affect the speedometer much.
Isn't the spare the same diameter as the stock 235/45/17? Running the spare temporarily shouldn't hurt anything unless you went with a taller tire such as 235/50/17 or a taller 18" tire.
So you're saying is that when you alter the width of your tires also affects the height of the rim and tire? I didn't actually know that, my apologies.
My factory rim and tires (235/45/ZR17) measure 24.5" (tires new this morning), my spare (125/70D17) also measures 24.5"
There's a few calculators you can go to. This one is cool since you can compare several sizes:
http://www.1010tires.com/tiresizecalculator.asp
Also- for those that have theirs towed, be sure to watch the flatbed tow operator. They usually end up jacking up the front bumper if not careful.
TopLevelPerformance
Dec 29, 2014 06:55 AM
flybyevo
16
Jun 7, 2012 06:57 PM
Evo1001
27
Jan 16, 2012 11:52 AM
LV///R
21
Apr 6, 2009 03:49 PM
