need help with shock!
Old Jan 20, 2012 | 03:06 AM
EPK's Avatar
EPK
hey guys I bought a set of bilstein for my 03 for the front shocks how do I know if the top plate are properly installed. Is there any marking on the plates or groove I need to look for ? I know its a noob question but any help is appreciated thanks!
Old Jan 20, 2012 | 04:22 AM
Smike's Avatar
http://www.evomoto.com/tech_articles..._article_id=22
Old Jan 20, 2012 | 09:40 AM
EPK's Avatar
EPK
Thank you Smike !
Old Jan 20, 2012 | 09:52 AM
deylag's Avatar
I have always wondered the mechanical reason for lining up the top plate to the bottom plate. Why do the plates need to line up?
Old Jan 20, 2012 | 10:16 AM
Smike's Avatar
Spring bind
Old Jan 20, 2012 | 11:06 AM
barneyb's Avatar
And, does spring bind make noise?
Old Jan 20, 2012 | 11:51 AM
Vivid Racing's Avatar
Yep. It'll cause a popping/banging sound. The spring binds up, and as soon as it gets a chance it unbinds itself.
Old Jan 21, 2012 | 02:28 PM
EPK's Avatar
EPK
OK I finally finish installing my Bilstein + Swift Spec R springs and I must say they are 10x better then the stock springs.... the car feel like brand new no more bumpy ride!! the car actually feel alot more stiffer and handle way better then stock springs. the best money spend lol. Now for an aligment not sure if I should just align to normal spec for DD? Anyone have the same set up with an alignment setting for normal DD?
Old Jan 21, 2012 | 02:31 PM
barneyb's Avatar
Yeah, just thinking that this could be the source of some of the front end noise complaints.
Old Jan 21, 2012 | 02:57 PM
n2oiroc's Avatar
front camber bolts set to -2, rear set to -1.2 to -1.4 and zero toe all around.
Old Jan 21, 2012 | 03:06 PM
EPK's Avatar
EPK
+1 thank you will get alignment next week !
Old Jan 23, 2012 | 04:07 AM
Smike's Avatar
For DD, I'd use the -1 bolt setting and -0.5 to -1 rear with no toe. Just will help tires last a little longer.
Old Jan 23, 2012 | 03:16 PM
WRC-LVR's Avatar
I agree with Smike for a DD. Tires will last longer at -1 F 0.5 r and zero toe. The Spec-r's are fantastic aren't they?
Bearing in mind this is a DD, you might replace some of the bushings like the stock front sway bar and rear sway bar ones with polyurethane units. It will feel crisper overall for not much money. DO NOT replace any of the control arm bushings that contain a spherical factory bushing unless they are shot. Replace those only with factory ones, not polyurethane....
Meanwhile enjoy your Spec-R's sir :-)
Victor Hong
Oct 31, 2016 10:21 AM
CottageLifer
Outlander Sport
14
May 11, 2016 05:45 AM
Chamama
Nov 6, 2006 01:56 AM
dbdude
23
Dec 11, 2005 11:41 AM
vietxscapeD
Oct 24, 2002 10:56 PM
