wheel bearings ?
Old Mar 20, 2012 | 06:57 PM
ryanholder24's Avatar
wheel bearings ?
when i get up to about 80 my steering wheel starts to vibrate then when i brake it vibrates more and also in 5th gear it lags and doesn't wanna pick up speed to fast but then i let off the gas and push down on it again it works fine
Old Mar 20, 2012 | 07:00 PM
4RETECH's Avatar
I'm thinking try a wheel balance and front brake rotor runout.
Old Mar 20, 2012 | 07:03 PM
alright but should fix the 5th gear thing to ? it happens very little
Old Mar 21, 2012 | 09:44 AM
chu's Avatar
chu
Check for bent wheel or unbalance wheel/tire. Wheel vibration does not matter what gear, but more at speed. In 5th usually means you're doing 55-65, which is about when yu will start to feel the vibration.
Old Mar 22, 2012 | 07:28 PM
stinkbomb's Avatar
i think 5th gear issue ur having is unrelated. ur on a 2.0 block? that could be your problem
def. get your wheels balanced. could have a bad tierod or balljoint also. lift wheel off the ground and see if wheel has any side to side and up and down play. if you take it to a shop for balance. take it somewhere you trust. tell them to check for play in front end. if you trust them and they are reputable hopefully they wont upsale u a bunch of $hit u dont need. and will be honest. g/l and report back findings
slicksta69
15
Jun 20, 2016 09:23 AM
edub173
Lancer Troubleshooting
Jan 14, 2014 12:14 PM
MR White
14
Mar 3, 2013 10:21 AM
ArtofRalli
Oct 20, 2011 01:21 PM
