rotor issue?
rotor issue?
i got new pads and had the oem rotors resurfaced and bedded them correctly about 5-6000 miles ago and everything was great now all of a sudden im getting really bad steering wheel shake when braking above 40 mph, does it sound like a rotor issue to everyone. i've cleaned the wheels and got touge factory centric rings and re-tightened the calipers and checked for a bad wheel bearing and still no luck.
FYI my tries are currently really worn down and im in the process of looking for new ones
May have a build up of pad material on the rotors. Can cause a vibration feeling when applying the brakes as the pad skips over the built up material. You can lightly hand sand the rotor surface and re-bed them in.
xexitenglishx
11
Dec 22, 2010 05:08 PM
rooney08
16
Apr 30, 2009 07:25 PM
