Who makes Titanium rims?
Originally posted by inariv5573
You guys have all been helpful to me. I may actually steer away from magnesium. Considering the weight is not much different from aluminum given the price of magnesium. Also I don't drive on perfectly smooth roads. I am looking into the SSR GT3's at TireRack. They are expensive but not as expensive as Mags. Maybe even the Works Rims. I am just not sure if I should convert to 18's. Will they affect handling that much?
Originally posted by mrgracer
OK, i think that you guys are wrong saying that titanium is heavier than aluminum, privide some proof and I'll kiss your feet.
A web search turns this up quite easily: http://www.mcelwee.net/html/densitie...materials.html
Aluminum weighs 2.643 grams per cc, Titanium weighs 4.5 grams per cc.
For comparison, Magnesium weighs 1.7 grams per cc, and Stainless Steel weighs 8.03 grams per cc.
Originally posted by Chris in HB
...I do wonder why my Cusco titanium front strut bar is so much lighter than the aluminum one...
But that's a different thing than saying that titanium is lighter than aluminum...
The fact is that different materials do have special characteristics that make them suitable for different applications. My primary expertise is in aluminum. Aluminum has very widely varying properties of corrosion resistance, strength and fatigue life. The best material for wheels would be forged 6069 T6. Good corrosion resistance and strength about 20% above 6061.
It was developed for compressed gas cylinders and is used now for bicycle frames and air bag cylinders. Aluminum weights vary from .097 to .101 lbs per cubic inch. If aluminum is heated above about 400 F it loses about half of its ultimate tensile strength.
Titanium is very difficult to work with but has comparable weight to aluminum with potential strengths twice as high. It is the best material for springs and exhaust systems if cost is no object. Aluminum will not work for either of these items because of temperature and fatigue limit problems.
To compare materials considerations are: weight, strength, flexural modulus, fatigue life, fatigue limit, annealling temperature, hardness, sustained load cracking characteristics, corrosion resistence in several types. Deficiencies in many areas can be overcome with design. Metals are my life.
Originally posted by jbrennen
What kind of proof do you want?
and thanks for the numbers, just never heard of that before. Thanks.
