speedline turini
Old Sep 18, 2012 | 04:53 AM
manash's Avatar
speedline turini
I want to change my stock bbs 17 wheels , I thing the speedline turini will fit my evo without any problem , any body know what they weight in 18 inches ? what width they are ? handling ?
any body have piture of them on white evo ?
I did search but I didnt find any thing ?
Old Sep 18, 2012 | 02:25 PM
GTWORX.com's Avatar
The 18x8 Speedline 2120 Turini should be around 18 lbs or a little over 8 kg.
I really like Speedline. Great wheels. I do not have any pictures of them on an EVO though.
Good luck.
- Andrew
Old Sep 18, 2012 | 06:38 PM
alleggerita's Avatar
White are 18"
Silver 17"
Attached Thumbnails speedline turini-img_3016-border.jpg   speedline turini-52040-mit-.jpg
Old Sep 18, 2012 | 06:43 PM
Solenoid's Avatar
Veteran: Marine Corps
Hello
Give us the full spec of the wheel & tire you want to run & we will run the numbers to check the fitment
Also, youre one of the few that live in the middle east that post. Where exactly are you? You note Palestine. Are you in the West Bank
Mike
Old Sep 19, 2012 | 02:20 AM
aann's Avatar
Is the 18x9 still available , anybody knows if it fit the evo ?
Old Sep 21, 2012 | 07:54 AM
manash's Avatar
I dont know , I have the stock bbs 17x8 with 235/40 .
what tyre should I run in 18 inches (speedline turini ) , and still with the same total wheels size ?
Old Sep 21, 2012 | 08:07 AM
Ludikraut's Avatar
The stock tires (Advan A046) have a diameter of 25.3 inches. To get a match as close as possible, go to tirerack.com then select the tire that you want and look at the detailed specifications for each size. Diameter is obviously impacted by the advertised tire size (eg. 255/40), but can also vary from tire to tire. I run a 265/35 on an 18x9 rim, partly because it is the exact same diameter as stock.
l8r)
Old Sep 21, 2012 | 08:27 AM
manash's Avatar
what tyre do you have ?
Old Sep 21, 2012 | 09:02 AM
Ludikraut's Avatar
Good Year Eagle F1 GS-D3 265/35R18. For street use it's about on par with the stock tire in terms of traction in the dry, although it's quieter and has softer sidewalls. Once you hit about 450whp, it's not really enough tire anymore, nor will it hold up well on a road course. However, in the wet it's very, very good.
l8r)
Old Sep 21, 2012 | 09:08 AM
manash's Avatar
thanxx
Old Sep 25, 2012 | 07:42 AM
aann's Avatar
Look what I found :
Old Sep 27, 2012 | 11:07 AM
manash's Avatar
that awesome , thanxx dude .
Old Nov 11, 2012 | 07:34 AM
manash's Avatar
okay . the wheels arrived 2 days ago , heres aquick pic :
[IMG] Uploaded with ImageShack.us[/IMG]
ShadowWalker010
Apr 12, 2015 03:35 AM
countdokoo
Feb 11, 2010 07:40 AM
2009GRAYGTS
Lancer Engine Tech
Aug 20, 2009 06:23 AM
MitsuJoe
14
Feb 26, 2007 07:47 PM
Claudius
Dec 12, 2001 04:02 PM
