Are these struts oem?
Sounds like a strut possibly. Check the springs to make sure they aren't broken/cracked or anything and check to make sure the spring is seated correctly. Another thing to try is suspend the rear and take a big pry bar under the tire and pry up and feel how the strut/spring reacts. Checking it if feels weak or unsmooth, etc. Compare the sides to each other. Judging by your mileage and the fact you had tiens on it previously it sound like a strut. In theory the strut should not affect ride height but i have read in other threads that it can cause the problem.
Edit: The car hasn't been in any accidents or tapped any curbs or anything has it? Bent suspension components?
UPDATED:
well i measured in a few places and the car is low on the right side rear by a 1/4 inch.
what i decided to do was suspend the rear of the car for a few minutes to decompress the strut i let it back down and got it within a 1/8" difference between both sides which isent to bad on ground where its usually a 1/4 to a 1/2" off. Then i pressed the trunk down and the height went down and would not return back up, the back right was also making some noise when pushing down on it after decompressing. Is it safe to say this is the Strut/spring??
I think its safe to say the car is ok and its in the suspension. Only other thing I can think of to try and its excessive is to swap the spring/strut assemblies and see if its lower on the left side then. Most cars they are the same but idk about the evo, I would think yes.
Edit: Just looked at this pics in your other thread they look the same so you can swap them side to side. Only other thing to look at is the spring seats and to make sure the spring is sitting properly and the strut rod isnt bent at all. Other then that I'm out of ideas.
