warped rotors
Old Feb 16, 2013 | 03:10 PM
skred's Avatar
warped rotors
I was wondering why my rotors warp Quickly.I always torque my lug nuts to spec and go easy on the brakes.Any input appreciated
Old Feb 16, 2013 | 08:29 PM
barneyb's Avatar
If you really do drive the way you say you do, your rotors aren't warped.
Old Feb 16, 2013 | 08:34 PM
merchomini's Avatar
unless someone else is driving your car
Old Feb 16, 2013 | 08:37 PM
barneyb's Avatar
Yeah, there's always that.
Actually it is pretty hard to warp a Brembo brake rotor - even for the guys that track it is rare. So, if you are driving like granny something else is going on.
Old Feb 17, 2013 | 06:08 AM
cfdfireman1's Avatar
They're not warped, read please. http://www.stoptech.com/technical-su...nd-other-myths
Old Feb 17, 2013 | 12:43 PM
skred's Avatar
stock pads
Originally Posted by cfdfireman1
So from reading this the problem is my stock pads causing the problem.Can you tell what pads I need for regular driving?
Old Feb 17, 2013 | 02:47 PM
TeRoy EvoIX's Avatar
I ran Hawk pads front and rear. Never had a problem.
Old Feb 17, 2013 | 04:09 PM
read it again
Slowly.
I think the answer to your problem could be in your first post. Don't "go easy on the brakes" tell us how you bedded in the pads.
This works on old and used pads and rotors as well as new.
http://www.essexparts.com/learning-c...rs/post/Bed-in
Old Feb 17, 2013 | 04:25 PM
AJCaron12's Avatar
What brand rotors/pads have you been using?
Old Feb 18, 2013 | 09:32 AM
Myth21's Avatar
Depends how much dust you want...Hawks could be very dusty and noisy.
Old Feb 18, 2013 | 12:26 PM
They are not warped!
Old Feb 18, 2013 | 12:57 PM
Dallas J's Avatar
Veteran: Army
The plane wont fly...errr... The rotors arent warped..
Lol, Question gets asked frequently if you cant tell from the tone of the usual suspects.
Old Feb 18, 2013 | 03:26 PM
Spend more money that will fix the problem. It's not how you're driving or installing the pads.
Old Feb 18, 2013 | 04:12 PM
And the world sure looks flat depending on where you stand.
https://www.evolutionm.net/forums/2801401-post8.html
Old Feb 18, 2013 | 04:30 PM
skred's Avatar
thanks braking gurus
I have stock brembo pads with advance auto rotors after turning stock once.The stock pads have 30000 on em.IM getting a shimmy in the steering wheel when slowing on the interstate from 80 to 70 not bad at low speeds .Is this a bedding issue ?Thanks for your input
