Weight Of Stock Wheels??
Old Feb 18, 2004 | 07:52 PM
nothere's Avatar
light wheels
I just had a set of SSR comps put on my car, they are quoted as being around 14 lb. That was light enough for me to overlook the fact that they look kinda like the stock wheel, though better.
17x8.5 under fifteen lbs! Neal has them as do others.
Old Feb 19, 2004 | 09:56 PM
blurr's Avatar
Aaron,
I have not weighed just the wheel, but I did weigh the wheel and tire @ 45.3lbs and then the tire was taken off (same day) and weighed the tire @ 24.2lbs.
That leads me to believe that the Stock wheel weighs 21.1 lbs.
I also weighed a Volk CE28-N 17x9x35 when I had them and it weighed 16.0lbs
All Item weights I have so far can be found here:
http://www.oursbourn.com/evolution/
-matt
Old Feb 19, 2004 | 10:01 PM
blurr's Avatar
I should also point out that the following wheels will not easily fit after you get the RRE JIC setup.
17x9x35
17x8.5x30
They will require a good bit of fender flaring, not just rolling. John will also likely kick you in the nuts, but after that be happy to charge you for the extra work required to make them fit.
-matt
Old Feb 20, 2004 | 12:36 AM
Cash Money's Avatar
Originally posted by Chris in HB
They are still on the boat from Japan, so I only have this to show you (Evo fitments are custom-ordered from BBS Japan) :
http://www.tirerack.com/wheels/Displ...k+w%2FMach+Lip
those are gorgeous!!! def post up some pics when you get them in and straped on!
Old Feb 20, 2004 | 03:38 PM
Evo Ate's Avatar
Sorry about my original post. The scale that I used weighed the combo in at 44.5lbs, but it must not have been accurate. I would take these guys word for it on the 20-21lb weight. Sorry for the miss info. My numbers on the combo where not to far out from some other peoples #'s though?????
Old Feb 20, 2004 | 03:46 PM
blurr's Avatar
Evo Ate,
Your info isn't necessarily wrong. I have found that there is a lot of weight in the tire tread. The difference in a brand new full tread tire to a tire with a good amount of wear can be 5 lbs or more.
-matt
Old Feb 22, 2004 | 12:39 PM
Evo Ate's Avatar
Thanks blurr...My tires are almost brand new. Never been spun or slid, only about 3000 miles.
Old Feb 24, 2004 | 03:15 PM
EvoNick's Avatar
Originally posted by blurr
Evo Ate,
-matt
Ah, so maybe that explains it. I just brought home some Gram Lights with Toyo RA1s mounted on them, and weighed them on my bathroom scale against stock. They weighed 3lbs more than stock..
BUT, the stock tire tread is almost gone, and the RA1s are unused.
FWIW, the stock combo weighed 40lbs, and the Gram Lights/Toyos weighed 43lbs, which is within 1lb of what they "should" weigh according to the manufacturers data. So presumably the scale is close to accurate.
Old Feb 24, 2004 | 03:20 PM
EvoNick's Avatar
Originally posted by ru4real
To weigh the wheel on a bathroom scale, don't put only the wheel on it. I recommend weighing yourself first, then weighing yourself holding the wheel. Bathroom scales may have an offset error and nonlinearity, so it should be more accurate that way.
If you use this method, I'd suggest trying to hold the wheel above your head if you can. I've tried this way before because it makes the most sense - bathroom scales are presumably designed to be accurate in the human weight range, but the ones I've used are very sensitive to off axis weight, which you can get by holding the wheel to your chest. Alternately, you might try standing on the wheel. But my digital bathroom scale won't allow me to do that. By the time I put the wheel on it, it's already locked in and won't acknowledge that I've added my own weight. Shouldn't be a problem with spring/dial types.
Old Feb 24, 2004 | 07:08 PM
timzcat's Avatar
You forgot one, you can also do a hand stand on the wheel and tire combo.
This is why bathroom scales suck. Although I have used them to corner weight a racing kart before. What else is so cheap.
Any shipping or grocery scale works well. Try going to the local market with a wheel and tire and see fi you can borrow the the meat scale for a minute. If so, don't shop there anymore.
Old Feb 24, 2004 | 07:19 PM
mifesto's Avatar
but enkei itself is aftermarket.. and 18 lbs are decent aint it?
Old Feb 24, 2004 | 08:21 PM
timzcat's Avatar
Yes, but the consensus is they are closer to 21 lbs a piece.
hoarder23
17
Feb 11, 2008 09:11 PM
LancerMarita
11
Oct 9, 2007 11:01 PM
EVOlutionary
Sep 27, 2007 11:40 AM
CombatCQB
Apr 14, 2004 08:32 PM
Alchemist
25
Feb 14, 2004 08:03 PM
