Bilstein B6-HD Vs Bilstein B8
Old Jun 27, 2013 | 11:23 AM
Kapok6's Avatar
Originally Posted by mrfred
Are you gonna try to reach a more helpful person there? Would be interesting to compare the valving numbers to the factory MR Bilsteins.
Maybe I am reading this wrong, but isn't that info in his post? he is doing a B6 (HD MR Bilsteing shock strut)/B8 Sport shock strut comparison. The valving #'s are in his post...
B6/B8
FRONT
Free Length: 19.35/18.7
Compressed Length: 13.35/13.39
Compression Valving: 58/60
Rebound Valving: 150/126
Rear
Free Length: 21.73/21.14
Compressed Length: 15.96/15.96
Compression Valving: 96/96
Rebound Valving: 147/147
Old Jun 27, 2013 | 11:37 AM
03whitegsr's Avatar
Meh, they aren't shorter so I could care less. I was interested more for a coilover conversion purpose.
Old Jun 27, 2013 | 11:52 AM
mrfred's Avatar
HDs are not the stock MR Bilsteins. From what I have read the HDs have firmer damping.
FYI - Ohlins also makes a damper for use with stock style springs, i.e., not coilovers. I think they can do whatever valving you want. A set is a bit spendy though - last I checked a few years ago, it was around $1800.
Old Jun 27, 2013 | 12:17 PM
Kapok6's Avatar
What is Bilsteins part #'s for the stock Evo Bilsteins then?
Bilstein only Has B6-HD, B8-SP, and B16-PSS9
http://cart.bilsteinus.com/search/mm.../drivetype=AWD
And Tire Rack shows the HD's as the replacement shock/strut for the MR...
http://www.tirerack.com/suspension/S...6&autoModClar=
Are these the Ohlins you are referring to?
http://www.maperformance.com/works-h...nsion-evo.html
Old Jun 27, 2013 | 12:51 PM
mrfred's Avatar
The HDs are different in appearance, and I have read that they have different damping characteristics, so I wouldn't call them the factory MR struts/shocks. I doubt Bilstein sells the factory MR struts/shocks directly, so not surprising that you can't find a Bilstein PN.
Those are the Ohlins, but they can be had without the Works Ride springs from places like GTWorx.
Old Jun 27, 2013 | 01:10 PM
9!'clipseDOHC's Avatar
FCOTM Winner
Just to add, the MR Bilstiens are indeed different from the HD's.
Old Jun 27, 2013 | 02:40 PM
Kapok6's Avatar
How come no one seems to sell the direct OE Bilstein replacement shocks/struts if indeed the HD's are not what they came with? Every Evo Bilstein search I have done returns the HD's as the replacements. Do you have to buy the OE Bilsteins for the MR through Mitsubishi?
Old Jun 27, 2013 | 03:12 PM
mrfred's Avatar
Seems to be the case.
Old Jun 27, 2013 | 03:17 PM
FCOTM Winner
Exactly. And with a $682 per (front) MSRP price tag, its no wonder you don't see them for sale new, you'd have to be retarded to spend that on a single MR strut when you can get the HD's for a fraction of the price.
Old Jun 27, 2013 | 05:02 PM
archie106's Avatar
These are the part numbers for the MR OEM Bilstein. Part # Front: MN101890 / Rear: MN101899.
They are available at oemmitsubishiparts.com or lancershop.com
Old Jun 27, 2013 | 05:50 PM
Kapok6's Avatar
Yeah, fk that noise.
So I guess a better question than the one originally posed would be, "how to the OEM MR Bilsteins, B6-HD's, and B8-SP's all compare to each other?" I was under the impression that the HD's were what came on the MR's, but seeing as how that is incorrect, how do the stock compare to HD?
Old Jun 28, 2013 | 07:25 AM
archie106's Avatar
Here is a good read to answer your question:
https://www.evolutionm.net/forums/ev...-comments.html
Old Jun 28, 2013 | 10:01 AM
GTWORX.com's Avatar
Bilstein MRs are only available from Mitsubishi....and ridiculously expensive.
Bilstein HDs are available from numerous sources (including us). Very slight appearance differences compared to MR, very close in valving but not exactly the same. A hair firmer IIRC but my shock dyno plot for both was on my laptop that was stolen 4 years ago when we were developing our GTWORX springs.
Bilstein Sports....well I have no idea . Definitely new to me. I'll do some digging, might be able to get a shock dyno plot for you guys but no promises. I'll see what I can do.
- Andy
Old Jun 29, 2013 | 07:52 AM
Kapok6's Avatar
- Andy
Yeah, I would be interested in seeing how they compare as I will be purchasing Evo shocks/struts for my 91 GSX and I am needing to decide between the B6 and the B8's.
Old Jul 11, 2013 | 08:36 AM
Kapok6's Avatar
I am pretty set on pulling the trigger on some B8's next week.
Any suggestions on springs? I have been reading on here and come to the conclusion that the prokits give the best drop and DD use.
Thoughts?
