Spring Rate Chart
Old Sep 2, 2005 | 06:01 PM
  #196
nj1266's Avatar
I think the best way to see if the stock dampers (shocks) are overdamped is to remove the stockers and put them on a shock dyno. The results will tell us which springs are best for the stock dampers. I believe that the stock shocks are overdamped, but believe is not science and we need proof.
If I go with springs only on the EVO, then I will for sure do a shock dyno to get springs that match the damper. It might end up that the stock springs are the best match for the shocks but I doubt that. It is possible that our feeling that the car is too stiff stems from the fact that our roads are CRAP. In Japan and Europe roads tend to be smoother and the EVO GSR/RS suspension was designed for such roads. This could explain why Mitsu came up with the MR suspension. You will not that the MR in Japan and Europe is even stiffer than our GSR/RS.
Old Sep 3, 2005 | 01:19 AM
  #197
JT-KGY's Avatar
I think US MR shocks are softer than regular Evos...
MR shocks responds faster.. but softer (according to SCC mags).
Old Sep 3, 2005 | 02:53 PM
  #198
nj1266's Avatar
I am talking about the European/JDM MR and NOT the USDM MR. I know that the USDM MR has softer springs than the USDM GSR/RS
Old Sep 7, 2005 | 11:07 AM
  #199
gaulrich2003's Avatar
I have seen it
Where is the alignment chart after lowering an evo. with curtain springs?
Old Sep 7, 2005 | 11:20 AM
  #200
voidhawk's Avatar
Not sure what you are asking? The alignment should be set to the same specs, regardless of what springs you use. zero toe front/back, -1/0 camber front/back are common specs for a daily driver.
Old Oct 11, 2005 | 11:54 AM
  #201
EVO-8-Silver's Avatar
Does anyone know about the US spec MR spring rate . ... thx
Old Oct 11, 2005 | 04:30 PM
  #202
JT-KGY's Avatar
Same as any other Evo sold since 03??
Old Oct 11, 2005 | 05:01 PM
  #203
Kayaalp's Avatar
You're joking, right? The MR has a totally different springs and dampers than other Evos.
Emre
Old Oct 11, 2005 | 05:04 PM
  #204
JT-KGY's Avatar
Emre
I know they have different dampers... not sure about springs... so I assume it's
the same... I never heard that MRs have different springs.. please prove me
wrong.
Old Oct 11, 2005 | 05:13 PM
  #205
Kayaalp's Avatar
I know they have different dampers... not sure about springs... so I assume it's the same... I never heard that MRs have different springs.. please prove me wrong.
Well, you assume wrong They're NOT the same.
Emre
Old Oct 18, 2005 | 07:20 AM
  #206
cc2's Avatar
cc2
KW Varient 3 Frt 515# Rear 340# seperate rebound & compression adj.
Old Oct 18, 2005 | 10:17 PM
  #207
Turbo-Ron's Avatar
I'm gonna bet my money on the Hotchkis
Old Oct 24, 2005 | 12:35 PM
  #208
cc2's Avatar
cc2
japanese forum?
Where are the German coil-overs?
Old Nov 16, 2005 | 06:27 PM
  #209
Rafal's Avatar
So is MR worth extra ca$h or not. Especially looking at this "Bilstein suspension". I know you get better wheels and 6 speed but I am especially curious about suspension.
Old Nov 16, 2005 | 11:07 PM
  #210
JT-KGY's Avatar
Emre
Still waiting for the reply that will prove me wrong....
I never heard of MR having different springs.. just 33% softer shocks..
