Spring Rate Chart
Old Apr 12, 2012 | 07:45 AM
  #346
Dallas J's Avatar
Veteran: Army
Originally Posted by DagYo369
good reading!! thinking about changing my springs around now from 12k front 10k rear to
10k-F and 12k-R. still though why wouldn't you want to get the heavier spring up front where the car is heavier and more pressure coming down on it say when braking etc. I new to the suspension game so sorry if question seems weak just trying to learn!
Just to add to MRFreds response, it might be easier to think of it as wheel rate. So yes, the front wheel rate will need to be higher compared to the rear because the 60/40 (or whatever it is) weight distribution.
Wheel rate is simply spring rate * ( motion ratio squared). Assuming the Front MR is ~0.91 and rear is 0.73 (an average along the arc, my measurements), then here's the wheel rates.
If you ran 12k/10k - front = 9.9, rear = 5.3.
Switching to 10k/12k - front = 8.3, rear = 6.4
Natural frequencies are a way to understand the balance of the spring to mass ratio and also compare against other cars, but to simply look at the ratio of balance f/r you can see the 10k/12k is closer to a balanced car in regards to stiffness with a little extra bias towards rear stiffness.
Old Apr 12, 2012 | 03:34 PM
  #347
DagYo369's Avatar
ahhh whabaki. makes sense now. I've made quite a few changes suspension wise to the car now and haven't been able to drive it yet but im going to try it first with the 12k fornt and 10k rear just to get a feel for it then swap them around just so i can get a better act/feeling of the car cause who knows how its gonna feel with all the changes now and i hate to change to much at once! thanks for the info though for sure gonna be swapping them around at some point!
Old Jun 29, 2012 | 12:31 PM
  #348
Evo Goblin's Avatar
Originally Posted by mrfred
The Evo front and rear suspension have different motion ratios (ratio of wheel travel to shock travel). The rear has a higher ratio than the front, so it needs a higher spring rate. Stock is 180f/225r.
..So does this only count for drop in springs and not complete coilover setups?
Because every after marked coilover set has either matching spring rates front to back or higher spring rates in front.
But all the after market spring only replacements have a higher rate in the rear.
Old Sep 15, 2012 | 02:05 AM
  #349
bone100's Avatar
That's probably due to the fact that the stock dampeners are valved for a stiffer rear where as a full coilover comes with different valving all together.
Old Jan 4, 2013 | 11:32 PM
  #350
mchuang's Avatar
Can the specs for the Tanabe springs be updated. On MAP's website it shows the specs as follows.
Application: Mitsubishi Lancer EVO8
Note: 1.5" F / 0.6" R
Old Apr 10, 2013 | 10:29 AM
  #351
MrJuls's Avatar
What are your opinions on the HKS Hypermax II for street use? I will also track the car from time to time.It's not my DD.
Old Aug 7, 2013 | 10:47 PM
  #352
NorCal Lancer's Avatar
spring rate for tein type flex coilovers? I'm not sure if the list is outdated, but from what I found it was this
Tein Flex:.................504lbs(9.0K).....448lbs(8.0K )....Adjustable
but then I found this, "i've called tein and they said the spring rates for tein flex is 12kg/10kg."
Old Aug 7, 2013 | 11:10 PM
  #353
Actually i need the spring preload for the tein type flex, thank you
Old Aug 26, 2013 | 03:10 AM
  #354
mrfred's Avatar
Originally Posted by Smike
First post officially updated with the most recent information I have directly from my contacts with Swift Springs USA and GTWorx.
Happy racing!
Smike,
I think that there may be a small error in the Swift spring description in the Spring Rate Chart thread. In the thread, you have, "MR differences: Rear MR springs are 3-4mm higher than the GSR versions. Reason is for the increase pressure the Bilsteins have."
If the Bilsteins have higher gas pressure and the goal was to have the same drop with KYB and MR Bilstein Evos, then it would make more sense if the MR springs where 3-4 mm shorter rather than higher.
Cheers, ...
Old Nov 16, 2013 | 03:40 AM
  #355
vgm10's Avatar
This info is really useful for suspension tuning/selection, thanks to all for posting your info.
Old Jul 11, 2014 | 11:57 AM
  #356
Sil'vr-Boi6's Avatar
anybody have spring rates for Racecomps?
Old Aug 15, 2014 | 08:15 PM
  #357
pangyau's Avatar
Hi guys,
Need your assistance & information.
What is the stock spring rates of OHLIN DFV (new from box)?
Anybody able to guide where to get Installation Manual for CT9A
Thanks in advance
Found the answer from Dealer. Front 10kg/ Rear 8kg.
Old Jan 1, 2015 | 10:15 AM
  #358
joeymass93's Avatar
anyone use the tanabe gp2100? currently looking for springs and wanted to know if anybody has any input on em?
Old Jan 2, 2015 | 05:44 AM
  #359
Stick w/the proven springs noted on the forum. Swift / Eibach / GTWorx
Old Jan 5, 2015 | 07:22 AM
  #360
heel2toe's Avatar
Stick w/the proven springs noted on the forum. Swift / Robispec / GTWorx
^Fixed
