That damn front lower control arm bolt!
Old Apr 13, 2016 | 01:56 PM
  #46
cts4g63's Avatar
Is that the only way to get it (cut the sub frame)? I can't imagine Mitsu sits there hacking up customers sub frames when/if this happens to them...
Old Apr 13, 2016 | 05:26 PM
  #47
SW20Mike's Avatar
Veteran: Air Force
If the nut breaks free from the inside, yes, cutting the sub frame to get access is the only way. So I'm still struggling with my bolt on the drivers side. My plan is to soak the bolt/area with PB blaster daily and heat the bolt up and use the two hammer method to shock the bolt hoping to free the bolt from the bushing sleeve. I'll keep doing that til Friday or Saturday and attempt removing again.
Old Apr 13, 2016 | 09:05 PM
  #48
LetsGetThisDone's Avatar
Heating the bolt up does no good, it will expand in the nut and sleeve and be harder to turn. You need to hear up the nut...
Old Apr 14, 2016 | 06:42 AM
  #49
cerevo's Avatar
In my case heating the nut did nothing, I still couldnt turn the bolt. It had completely seized to the bushing. If you had a way to get some Kroil or "pimp juice" in there you might be better off.
p.s. "Pimp Juice"
http://www.instructables.com/id/Home...netrating-oil/
Old Apr 14, 2016 | 07:28 AM
  #50
njboy's Avatar
Yes this right. Instead freeze the bolt. There are cans that freeze spray. Check google.
Old Apr 16, 2016 | 08:29 AM
  #51
SW20Mike's Avatar
Veteran: Air Force
Welp, haven't given up on many upgrades on my car, but this is the 1st one. The driver's side bolt would not come out, no matter what. I finally turned to an impact, which would still only move the bolt 1/8 of a turn, either way. The head of the bolt is now pretty rounded out, and instead of risking breaking the bolt or the nut in the subframe, I'm just gonna let it be. Maybe one day I'll take it to a Evo shop and have them mess with it. You win lower control arm bolt, I surrender... Good luck for others who have to remove their lower control arm for any reason.
Old Apr 19, 2016 | 07:36 AM
  #52
GTijoejoe's Avatar
Old Jan 20, 2018 | 10:45 AM
  #53
Paul Cholo Snow's Avatar
These subframes are stupid
Taking off driverside lower control arm the ball joint bolt came out fine the bolt that bolts upward came out fine but that one that goes through the bushing sideways ( l--- ) the nut that's welded in the subframe broke loose believe it or not the subframe actually has a hole rusted right there but I can't seem to get a wrench or anything on it to stop it from spinning any suggestions on how to get that bastard? I'm having a difficult time here lol 2002 lancer
Old Jan 21, 2018 | 08:34 AM
  #54
cerevo's Avatar
You've gotta cut that out so you can get the wrench or socket in there. There's no other way unless you can get a welder in the hole that rusted and weld the nut down.
Old May 12, 2018 | 09:54 PM
  #55
yellowevo82's Avatar
I used two cans of map gas, 4 industrial cans of pb , 2 foot 1/2 breaker bar and a 1400 ft.tq impact wrench and nothing
Old May 13, 2018 | 09:42 AM
  #56
SW20Mike's Avatar
Veteran: Air Force
Likely because that nut is seized or already broken free and is free spinning. You are gonna have to cut a hole to get to it to hold in place or weld in place. It sucks...
boostawd16
39
Jan 13, 2025 04:47 PM
EvoDan2004
72
Sep 10, 2017 07:29 AM
RT78
Feb 12, 2017 11:06 AM
OX
Dec 30, 2016 05:52 PM
zacc
Oct 19, 2016 10:40 AM
