Help!! 18x10 +38 rpf1s
Old Jan 16, 2014 | 08:01 PM
06evol's Avatar
Just purchased a set of rpf1s for my Evo 9 what size spacers will I need for the front?! Size 18x10 +38
Old Jan 16, 2014 | 10:38 PM
Kada__85's Avatar
20mm spacers for the front.... id also recommend 5mm for the rear as this wheel doesnt clear the trailing arm in the rear
Old Jan 16, 2014 | 11:07 PM
06evol's Avatar
Anyone have pics of this setup? Thank you for your help bro. Just wondering how far they will stick out if I do that 20mm spacer.. Or is there a different brake kit I could go with so I don't have to use spacers
Old Jan 16, 2014 | 11:17 PM
Kada__85's Avatar
just search, youll find what youre looking for. they wont poke out much in the front, +18 offset is perfectly fine for the front.
i wouldnt suggest swapping out your brake kit, but rather getting wheels with a better fitting offset. 18x9.5 +15 rpf1s dont require a spacer but youll need a roll and pull to fit them in the rear
Old Jan 17, 2014 | 03:16 AM
TougeGod7's Avatar
this i run the exact same setup with a 285/35-18 hoosier and they fit. without the 5mm rear spacer it rubs the trailing arm.
Old Jan 17, 2014 | 06:16 AM
06evol's Avatar
Awesome thanks for your help guys I appreciate it I'll post pics and let you guys know how mine turned out
Old Jan 17, 2014 | 09:57 PM
XcreatonX's Avatar
I am also running the same setup. 18mm Spacer up front and a 6mm in the rear. I did roll and pull the rears and run a fender mod on the front to be safe.
Old Jan 22, 2014 | 07:44 AM
OL_DIRTY's Avatar
Where are you getting your spacers? Can you post better picture of your fender manipulation? Do you need crazy spring rates to control the grip?
Old Jan 22, 2014 | 08:29 AM
XcreatonX's Avatar
My front spacers are slide on hub centric from JMfab. The rears are slide on from Ciro Design. I am running 11k front and 12k rears. The fender mod is pretty simple you just put a piece of metal where your fender meets the chassis to space it.
Old Jan 22, 2014 | 11:31 AM
chu's Avatar
chu
The front fender mod isn't necessary in my opinion. Otherwise, the advice is dead on for running this setup!
Old Jan 22, 2014 | 10:38 PM
8AVETTE's Avatar
Get quality spacers! I would recommend getting extended studs in the rear.
Old Jan 23, 2014 | 01:14 AM
TougeGod7's Avatar
+1
Old Jan 23, 2014 | 01:53 AM
Tibbar's Avatar
Why is it that those 18x10 +38 wheels with 20mm spacers at front seem to fit so well, but 18x10 +18 such as xd9's have a lot of poke? It should be the same, shouldn't it?
Old Jan 23, 2014 | 03:01 AM
TougeGod7's Avatar
aggressive camber most ppl running the RPF1s are tracking and, like me, have at least 3* of camber in the front, which might be the reason they fit better
dsmdion
For Sale - Wheels / Tires
Mar 29, 2016 09:05 AM
boostincincy
Sep 7, 2014 02:36 PM
MattevoVIII
May 16, 2014 01:56 AM
TeRoy EvoIX
26
May 19, 2013 05:48 AM
illvolution
Sep 24, 2012 02:22 PM
