18x9.5s
Originally posted by 4drbike
Here is another... Not much room to go any wider as the top of the tire just barely fits inside of the fender well (almost flush)... I LOVE the look though.
it's sad we can't go much wider than 235's
cuz the fender flares beg for a wider setup
obviously evo is not a vip sedan but i've seen crazy rim/tire
setups........how does 225's on 10.5" rims sound
Like the rims, I am wondering about rubbing once it is lowered. If you can go a little wider on your tires, if not it still looks good. Don't worry about Diesel he's a hater, just look at his other threads he comments in
Originally posted by Crazy4Cars
That is not correct, in my case, I run 18x9.0 et 29 255/35/18 but been the other wheel 18x9.5 et35, you could run the same tire as mine no problem.
I may have to try that setup next. The extra grip should definitely help for putting down huge power to the wheels.
Yeah, Diesel is a trip... makes me want to laugh.
He obviously enjoys making snide remarks... more power to him. People like him don't bother me one bit.
I have 18 X 8.5's with a 245/40 and they rub making sharp turns. That was before it was lowered. You have to be rubbing somewhere. LOL
I think I'm gonna buy those Kumho's in a 235/40 and just be done with it.
We'll see what happens when I lower it today.
Where was yours rubbing? You'll love the Kumhos.
Before it was lowered, it was rubbing when the wheel was turned all the way. You could see the front tire actually touch the splash gaurd when turned. Now that it's lowered, it rubs the top of the fender ever so slightly when I hit a big enough dip in the road or corner hard.
I have the Tein S-Techs right now, but I have the H-Tech's siting at a buddies house that I'm gonna put on this weekend. If those don't help then I'm buying tires.
Post some pics. once it is lowered
also what method are you using to lower (springs, coilovers)?
I'll post some pics today
so.. it's a 17x9's right?.. 35 offset as well?
How did you take care of the rear fender problem?..
Did you roll it yourself?
Thanks,
Thanks,
Originally posted by Changy
Iam running 22, 9J offset and 255/40/17 TE37s now. And my car is lowered so your rear will give u problems. But ive sorted that out now. U can take a look at my photos on my profile.
Cheers
Cheers
