Brake dont seem biting enough.
Old Jul 13, 2014 | 10:43 AM
jameswwt's Avatar
Hi, i would hope to get some advise as my current evo 5 front brakes seem not biting enough. Ive replaced all the brembo service kit, using endless ccr 800cc pads (f & r), project miu front rotors, steel braided brake hose & project miu brake oil.
Beside changing to a bigger size calipers, is there any ways of improving my braking performance?
During track days or emergency braking, i usually hv to pump the brake few times to get better bite.
Is there a way to modify a bigger brake master cylinder?
Thanks in advance.
Old Jul 13, 2014 | 03:40 PM
Dont know much about the EVO5 but unless Mitsu under spec'd the MC I doubt that is your issue
My guess is a possible bedding issue or inadequate pad choice for its use
Old Jul 13, 2014 | 07:06 PM
jameswwt's Avatar
Hi, thanks for yr kind sharing but is it norm for all the later Evo's as well?
Any other possible way to improve the bite?
Thanks
Old Jul 15, 2014 | 09:25 AM
crazybaldhead's Avatar
You need to research the heat rating of the pads. Some pads are very street friendly and will have max friction even when cold. Others need some heat to bite, like the hawk HPS.
Evo brakes tend to be a little "wooden" when cold anyway.
Old Jul 15, 2014 | 10:47 AM
jameswwt's Avatar
Old Jul 15, 2014 | 11:04 AM
NSDQ's Avatar
If you didn't bleed the system correctly there could be air in the lines causing your calipers to not bite all the way down. I'd check that first before investing in more hardware.
Old Jul 16, 2014 | 04:09 AM
jameswwt's Avatar
Hi NSDQ,
yes ive bleed the brake system cautiously.
Kracka
22
Aug 17, 2016 09:31 AM
Grimgrak
Jan 30, 2013 09:47 PM
toyotabike
Apr 12, 2011 12:33 PM
stockEvoIX
41
Sep 1, 2008 02:05 PM
caymandiver75
Nov 21, 2004 06:52 PM
