Question about replacing one tire -_-
Old Mar 10, 2004 | 02:17 PM
vicbdn's Avatar
Yeah, so this happened a long time ago, but I'm just recently going to handle it. I found 2 pretty shallow but still serious slashes on my front left tire sidewall... Well one was a slash, and one looked like someone took a small bite into my arm and left my flesh hanging =\. So i need to replace ONE tire...hopefully. The front right tire was recently replaced from an accident so it only has 100-300 miles on it. THe back two tires are fine, but they have ~1700 Miles on them...
Normally I wouldnt be so worried, just I've been told that the differences in the wheel tread could cause problems? Should I go order just one, and have the low mileage tires paired up front, and the higher mileage ones in back? Would that work out, or would that mess up my suspension? Thanks~
Old Mar 10, 2004 | 02:19 PM
Neal@tirerack's Avatar
Four-wheel drive and all-wheel drive vehicles are equipped with additional differentials and/or viscous couplings that are designed to allow momentary differences in wheel speeds when the vehicle turns a corner or temporarily spins a tire. However, if the differentials or viscous couplings are forced to operate 100% of the time because of mismatched tires, they will experience excessive heat and unwarranted wear until they fail.
This necessitates that four-wheel drive and all-wheel drive vehicles use tires that are very closely matched. This is because different diameter tires roll a different number of times each mile as a result of the variations in their circumferences. Tire diameter variations can be caused by accidentally using different sized tires, tires with different tread designs, tires made by different manufacturers, different inflation pressures or even tires worn to different tread depths.
As an example of different tire diameters resulting from tires worn to different tread depths, we'll compare two 225/45R17-sized tires, a new tire with its original tread depth of 10/32-inch and a second tire worn to 8/32-inch of remaining tread depth. The new 225/45R17-sized tire has a calculated diameter of 24.97", a circumference of 78.44" and will roll 835 times each mile. The same tire worn to 8/32-inch of remaining tread depth is calculated to be 1/8" shorter with a diameter of 24.84", have a circumference of 78.04" and will roll 839 times per mile. While the difference of 1/8" in overall diameter doesn't seem excessive, the resulting 4 revolutions per mile difference can place a continuous strain on the tires and vehicle's driveline. Obviously, the greater the difference in the tires' circumferences, the greater the resulting strain.
This makes maintaining the vehicle manufacturer's recommended tire inflation pressures and using "matched" tires on all wheel positions necessary procedures to reduce strain on the vehicle's driveline. Using "matched" tires means all four tires are the same brand, design and tread depth. Mixing tire brands, tread designs and tread depths may cause components in the vehicle's driveline to fail.
Mismatched tires or using improper inflation pressures for all-wheel drive and four-wheel drive vehicles can also result in immediate drivability problems. Some Control Trac equipped vehicles in 4Auto mode may exhibit a shutter on acceleration and/or a noise from the front driveline and transfer case while driving. Some all-wheel drive and four-wheel drive vehicles may exhibit axle windup or binding while driving. Some four-wheel drive vehicles (manual or electronic shift) with a two-wheel drive mode may refuse to shift "on the fly" into 4x4 Auto or 4x4 High at highway speeds.
You can read more at: Matching Tires on AWD Vehicles (Tire Rack Tech Center)
Sorry for the long post
Old Mar 10, 2004 | 03:24 PM
vicbdn's Avatar
So to sum up what you're saying is...
Bad.
Thanks for the info neal.
mainly...I'm wondering if
fontend
[] ------- [] - Left New, RIght100-300 M
[] ------- [] - ~1700 miles
-backend-
= bad. Just posting real quick to clear things up, no time to read through most of what you posted, got a chem exam to catch . I'll be sure to post something back when i'm dont tho.~
hammerevo
28
Nov 16, 2009 12:20 PM
03evo**
For Sale - Wheels / Tires
Mar 28, 2008 04:08 PM
sgand
21
Nov 16, 2007 08:26 PM
Thegame
Jul 11, 2005 02:42 PM
Thoe99
Feb 4, 2005 12:15 PM
