Toe & Camber Verification
Old Mar 11, 2004 | 10:59 AM
4-BNGR's Avatar
Are the following the "factory specs": Thanks in advance...
FRONT CAMBER -.30
FRONT TOE -.34 (total)
REAR CAMBER -.50
REAR TOE - .45 (total)
Old Mar 11, 2004 | 11:13 AM
4-BNGR's Avatar
Not all at once guys
Old Mar 11, 2004 | 01:19 PM
Trbo Dad's Avatar
Here ya go:
Stock Alignment #’s For Evo 8
Front:
Toe-in mm (in.): 0 +/- 2 ( 0 +/- 0.08)
Camber (Selectable from 2 options): -1deg +/- 30' or -2deg +/- 30' (left/right deviation within 30')
Caster: 3deg55' +/- 30' (left/right devitation within 30')
Rear:
Toe-in mm (in.): 3 +/- 2 (0.12 +/- 0.07)
Camber: -1deg +/- 30' (difference between right and left within 30')
Hope this helps.
Old Mar 11, 2004 | 03:02 PM
1BADSUV's Avatar
HI
I just went through this with my EVo today. My Advan's in the front were worn inside and I went in today to get the alignment.
Here are my actual spec's: LF -0.4 Camber RF -0.03
after alignment. LF 3.2 Caster RF 3.5
LF .02 Toe RF .09
LR -0.5 Camber RR -0.7
LR 0.12 Toe RR 0.08
I am working with Mitsu on replacement of my front tire's right now.
Old Mar 12, 2004 | 07:37 AM
JustDSM's Avatar
https://www.evolutionm.net/forums/sh...threadid=61716
2nd post down. Those were my confirmed stock settings.
Old Mar 12, 2004 | 08:39 AM
4-BNGR's Avatar
Thanks guys. I'm 13K into the car and the tires are shredded b/c the toe settings are atroscious. I'm looking to have replace all 4.
Where does it state that Mitsu must bring the settings to "spec" before the dealer can deliver the car to the customer.
Thanks again.
Old Mar 12, 2004 | 08:54 AM
93civEJ1's Avatar
yeah where do you guys go get your alignment done?? Mitsu dealer??? i think im gonna go to mine, and suggest what settings I want that are available.
Old Mar 12, 2004 | 11:38 AM
1BADSUV's Avatar
Hi
My Mitsubishi dealer here locally sent the car out to a body-shop to do the alignment. They gave me a before and after alignment print-out. I am working with the local DSM of the dealership on replacement of my front tire's.
Old Mar 12, 2004 | 04:04 PM
JustDSM's Avatar
I went to a Big "O" Tire and the tech there had absolutely no problem at all aligning it my custom spec. He even offered to let me sit in the car while he aligned it. He also gave me 30 days of trial and error to test out the settings. If I didnt like it, re-alignments for 30 days were free. All for $55.95.
Old Mar 14, 2004 | 07:49 PM
Trbo Dad's Avatar
Firestone.
Lifetime alignment for about $110.
I take it in every few months or whenever I change anything on the suspension.
Old Mar 14, 2004 | 08:00 PM
spyderturbo's Avatar
Originally posted by Trbo Dad
Firestone.
wow...I gotta look into this around here!
Was it a special on the side deal or something or should any firestone shop be able to do this?
-Rob
Old Mar 14, 2004 | 08:34 PM
Trbo Dad's Avatar
Any Firestone. If you catch a speacial is when it is cheapest though.
QCRVR
Outlander Sport
Oct 4, 2016 02:29 PM
hispanicpanic
10
Mar 1, 2014 04:07 PM
19psi
13
Oct 8, 2006 09:08 PM
TexasRS
15
Dec 26, 2004 09:44 PM
ferrarokid
May 10, 2003 02:18 AM
