Camber/drop help a noob
I have a set of rpf1 wheels in 17x9.5 +38 wrapped in Hankooks 255/40/17 tires. Recently installed fortune auto coilovers amongst other things. Car is on stands for now(calipers being powdered and rebuilt) but I'm curious, how much camber on the front since I have to use a 20mm spacer would be recommended to not jack up my fender. I'm trying to be about a fingers gap or two in clearance from top of tire to top of fender. I won't be hurting suspension travel as these are lowered from the perch not spring. I'm planning on ordering the whiteline kits so the roll center is in check. Thanks guys.
i am on 18/9.5 +35 on broadway static coils, with 255/35/18 tires and run just under 2 degrees camber in the front, tucking just the tops of the tires in the front and i do not rub at all. i rolled just the inner edges of my front fenders to be safe but it really wasnt needed. with 17's and from what your describing as less drop, you could run whatever front camber setting you want it sounds like and not have any problems.
rodeopunk_je87
Aug 5, 2014 03:45 PM
monstar 8
19
Sep 18, 2007 01:51 AM
TexasRS
10
May 15, 2005 06:13 AM
scorke
Sep 18, 2004 02:38 PM
