urethane = mustache bar delete?
First off how did this turn into a weight saving thread smh
Anyway you don't have to drop the subframe to switch out he rear diff bushings. I would just get the Torque solutions MBE kit with the solid diff inserts and call it a day. I just installed mine and the noise isn't as bad as everyone says and it's def gets rid of the clunking and any other bad characteristics affiliated with the stock bar. Yes it saves weight too
I reread the post you made it said drop the subframe to put bushings in the Mustache bar not the diff brackets that's what was confusing as the thread is focusing on the MBE(Mustache bar eliminator) kit. Yeah Torque Solutions kit is cheap and def does the trick.
I think an MBE kit is on my short list. I'm trying to shave weight.
i don't mind the down sides since i don't daily the car.
detroit pistins
Aug 18, 2016 02:09 PM
MisUnderStood
20
Jan 18, 2016 05:57 PM
nlp187
Jul 8, 2012 10:32 PM
EGbeater
May 24, 2012 10:06 AM
so I can convince the wife we need subframes
