RRE Great Shop !!!. Great Service...
I recently had them work on my car , and since i track the car doing suspension upgrade was a must . But since i have so much to learn my next step was to do at RRE their alignment, rear sway bar and bushing set up by John L. Mueller ...
The car handles night and day , all wheels now are in full contact , takes turns amazing ... Plus excellent customer services by the guys at RRE...
Can't wait till i take the car back to the track and see what it can do on hard corners..
+ i had the chance for John to drive the car around (test run ) and see what the car can do at its best ...
i still can't believe what is capable ...
Thanks a lot John for your amazing work "YOU GUYS ROCK !!!!"
My next step is the JIC set up by John @ RRE ( let John work the magic on the car )
You guys have a customer for life ....
Nevermind about the bushing question. I just checked the Road Race site and saw that they are urethane. Do the new bushings make much noise? And I heard that you really need to be able to lube urethane bushings or they will have a problem with binding.
Originally posted by Hot Feces
May I ask how much all this cost?
Can't afford JICs, and this sounds like the next best thing.
You can add the bushings for 90.00 + installation . Theres no noise level waht so ever with the bushings (not that i have heard or notice)
If you can not afford the JIC and you plan to track the car , this is the best thing . The only reason i didn't go right away with the JIC magic set up by RRE , is because i want to get the best out of the stock suspension and learn to drive the car alot better on the track. Before i go that route , but believe me is on the LIST !!
Give RRE a call 1-562-777-1522
or email john .. to set up an appointment. Believe me its one of the best investment i have made to the car .
Originally posted by GokuSSj4
... The only reason i didn't go right away with the JIC magic set up by RRE , is because i want to get the best out of the stock suspension and learn to drive the car alot better on the track. Before i go that route , but believe me is on the LIST !!
With stiffer suspension and chassis setup, weight transfer, hence chassis dynamics' changes in cornering are significantly faster and different in feel than the stock setup. You will have to develop a new levels of senses and reflexes to pickup what the chassis is doing underneath you or the messages it is sending back to you. If you get too acustomed to the stock setup, your bottom's feeling and reflexes will be too slow to properly drive the new setup.
Even shift points will change, advanced driving techniques; such as trail braking and various corner entry points will also change. Especially trail braking becomes a whole new adventure
I hope you don't take this as a criticism, I just wanted to point out few potential downfalls related to track driving and chassis setup.
Just my 1+1 cents, happy tracking
Aaron on a stock RRE'ized suspension with their rear bar on toyo ra1's ran 2:07's at Buttonwillow...that's a stock HP car My Stage IV Buschur got me to 2:04's on the same rubber. (man I got to learn how to drive) Way to go Aaron...
