Evo Ix trailing Arm
Old Apr 14, 2016 | 08:28 AM
  #31
SWOLN's Avatar
So why no use the RaceFab Rear Trailing arms? It's about $550.00 USD.
Old Apr 15, 2016 | 05:23 AM
  #32
LetsGetThisDone's Avatar
Originally Posted by Balrok
Gents,
FYI, the aftermarket arms come with a MOOG ball joint, #K772, which will work for 20 bucks .
By aftermarket you mean RTErnie? If that's the case those just got really easy to make myself for less than $200....
Old Apr 16, 2016 | 11:28 AM
  #33
deylag's Avatar
Yup I looked at a set that RTErnie made and cross referenced the part number. When you get the ball joints they have a different number on them. SMH, I dont know why MOOG does that.
Old Mar 6, 2018 | 05:53 AM
  #34
suby2evo's Avatar
Gents,
Wait so moog k772 can be used as a replacement on the oem arms? have you or anyone else done this? That would be amazing
Old Mar 6, 2018 | 07:22 AM
  #35
heel2toe's Avatar
No, the K772 is the "Mopar" ball joint which is used on some aftermarket arms like the R/TErnie ones for example. The picture they show of those online is exactly how they look in that they thread into the arm vs being pressed in like the OEM piece.
Old Mar 21, 2019 | 01:24 PM
  #36
tegster1's Avatar
Was just reading this thread as there is a chance I might need to be doing some ball joints in the rear. Came across this just in case anyone is in need of them. https://www.maperformance.com/produc...SABEgJ7_vD_BwE
Old Jun 20, 2021 | 03:56 AM
  #37
WelDun1's Avatar
Originally Posted by deylag
Sorry man you can only order the rear trailing arm or get a replacement boot. They do not sell the ball joint by itself.
Aftermarket Trailing Arms are available but they are more expensive than an OEM arm.
http://professionalawesome.com/produ...trailing-arms/
LH Trailing Arm : MR594607
RH Trailing Arm : MR594608
This is definitely NOT TRUE . You definitely can buy just the ball joint. Maybe not through Mitsubishi, but there are several companies that sell them. Hard Race makes/Made them, but they are getting harder to find, but if you Look on eBay, you will find some... And remember that all 3 rear ball joints are the same.
Old Jun 21, 2021 | 05:58 PM
  #38
deylag's Avatar
Congratulations! You bumped a three-year-old thread to correct me on something that was discussed in the thread. I see that you are really trying hard to get that post count up. BTW, I encourage you to look through all my other posts and correct me on any other post you deem incorrect. That will help us both.
4cdndctn
Feb 11, 2011 09:21 AM
Solo II Evo
Jan 10, 2011 01:45 PM
Pr3z
Jul 17, 2008 02:17 PM
Torre from Va.
Apr 30, 2008 04:43 PM
justchil
Oct 1, 2007 09:41 AM
