View Poll Results: Brake Poll - warping and pad type?
Not Warped - Aftermarket Pads
11
7.80%
Not Warped - Stock Pads
65
46.10%
11
7.80%
Warped - Stock Pads
54
38.30%
Voters: 141. You may not vote on this poll
Old Feb 9, 2005 | 05:04 PM
  #46
jfh's Avatar
jfh
I have used both stock pads and Carbotech Bobcats. The Bobcats were far to noisy for me and I removed them after about a week. My stock pads exhibit symptoms of rotor warping almost monthly but it is just pad transfer. It goes away after a few evolutions of threshold braking. Turning the rotors will also cure the problem temporarily but significantly reduce the life of the rotors. Try to burn off the pad build up before puting the rotors on a lathe.
Old Feb 9, 2005 | 10:28 PM
  #47
erioshi's Avatar
While I didn't like the Carbotech Bobcats I definitely like the Carbotech XP-8s I've been running. If I use plenty of anti-squeal they are fine (quiet) between track days, but I tend to burn the anti-squeal off at the track. The XP-8s are significantly better than stock in both bite and fade resistance.
Looking at the results of this poll has given me an idea for another one. I'm still looking for the "miracle cure" to the pad transfer/rotor warping problem.
Old Feb 9, 2005 | 11:49 PM
  #48
RaceBiscuit's Avatar
Just curious, of those who've had these problems, has anyone gotten new ROTORS and had the problem(s) go away entirely???
