Rotor suggestions
Old Nov 16, 2015 | 10:03 PM
cts4g63's Avatar
Rotor suggestions
Thoughts on these rotors...
Don't need anything for the track, street performance preferred, only need front.
Nearly brand new Hawk pads all around.
Other suggestions? Trying to stay around $200
Old Nov 17, 2015 | 12:44 AM
MR. EVO MR's Avatar
ill bet you $200 your rotors dont need replacement!
Old Nov 17, 2015 | 03:36 AM
Jonno99's Avatar
Just get some generic blanks, if your not tracking
Old Nov 17, 2015 | 05:18 AM
Centric rotors are what we use for the purpose you noted
Old Nov 17, 2015 | 06:00 AM
cts4g63's Avatar
There's a vibration when braking.
I just bought my Evo, so inform me..
Any in particular that produce a minimal amount of dust?
Old Nov 17, 2015 | 06:28 AM
You have my word that these rotors produce zero dust
Old Nov 17, 2015 | 06:55 AM
cts4g63's Avatar
Didn't realize Centric was a brand
Centric blanks are only $82/rotor, not bad!
EDIT:
Going with the Centric Cryo-Stop rotors. $200/set on Lancer Shop.
And just realized I related brake dust to rotors. **** it, it has been a long morning...and the DMV didn't help.
Old Nov 17, 2015 | 07:29 AM
I would forgo the cryo treatment & just get the high carbon Centrics from Tire Rack or other vendor beside Lancer Shop.
The high carbon is already an upgrade from their normal carbon rotors. No need to spend for the cryo IMO
$68.00 ea. high carbon from Tire Rack
Old Nov 17, 2015 | 08:10 AM
LetsGetThisDone's Avatar
You don't need new rotors. You need to get the pad deposits off the current ones. Either try rebedding the pads, or getting the rotors machined, than rebedding the pads. Although, it'll likely come back, Evo's are finicky about brake pad selection.
Old Nov 17, 2015 | 08:45 AM
cts4g63's Avatar
Thanks
You don't need new rotors. You need to get the pad deposits off the current ones. Either try reversing the pads, or getting the rotors machines, than Rene's the pads. Although, it'll likely come back, Evo's are finicky about brake pad selection.
So the previous owner either didn't install correctly, or didn't break in the new pads/rotors correctly? Elaborate, if you don't mind.
The rotors really do not look/feel worn, but there is definitely a vibration when braking.
Also, there is a tiny squeak for a split second that happens when stopping from ~5mph to 0mph.
Old Nov 17, 2015 | 10:34 AM
Edited the autocorrect errors. Nothing really to elaborate on. Brake "shaking"/vibration is 99.99% of the time due to uneven pad deposits on the rotors. This can usually be cleaned up by rebedding the pads. Sometimes the rotors need be machined and than the pads need to be rebedded to the fresh rotor surface.
You don't need new rotors. You need to get the pad deposits off the current ones. Either try rebedding the pads, or getting the rotors machined, then rebedding the pads. Although, it'll likely come back, Evo's are finicky about brake pad selection.
Old Nov 17, 2015 | 10:38 AM
cts4g63's Avatar
So if the vibration is likely to come back, wouldn't it just be prudent to change the rotors and remove deposits/rebed the pads correctly?
Old Nov 17, 2015 | 05:15 PM
Because it will do the same thing on new rotors if the deposits are due to poor pad choice, and not just improper bedding...
Old Nov 17, 2015 | 07:37 PM
cts4g63's Avatar
I see. Are Hawk pads really that bad?
Old Nov 17, 2015 | 08:43 PM
Depends on which ones they are. Their higher end sport/race stuff is good. I don't have experience with their more standard stuff.
