Can someone tell me what springs setup he has exactly?
From what I know, he's running bilstein bps with swift springs (front 20k, rear 18k)
Which swift springs exactly tho? Sport, sport spec-r, metric? I want his exact drop. I have bilstein's with skunk 2 lowering springs, I'm also running the same wheel set up as him, volk te37rt 18x10.5
Thank you.
He is on adjustable coilovers. No one makes lowering springs for that amount of drop. Good luck ruining your car.
No, I don't know lol, that's why I'm asking. All I know is his spring rate. I don't know what the length of the springs are or the inner diameter of the spring or what sort of swifts he is running. That's what I want to figure out, what custom swift springs will work on the bilstein's. And let me repeat myself, "I would, but I honestly don't need all the extra settings, it's not like I plan to track my vehicle anytime soon." I want to stick to my bilsten's for now, and just upgrade the lowering springs. I don't NEED the all the settings of dampening and height adjust-ability on the fly. Remaining static is fine for what I'm doing. Thank you.
You're missing the point: stock Bilstein can't go that low on any springs that are sold. Sure you can cut them, but that's horrible and should never be done
He's not on stock Bilstein like you are
You need the adjustability of adjustable coilovers if you want to go that low. You need to be able to play with ride height (stock Bilsteins have no control over this outside of springs), you need to be able to adjust spring rates (stock Bilsteins are limited to what Swift, GTWorx, Tien, etc., etc produce), you need to be able to adjust camber (you can get adjustable camber plates, but in stock form the Bilsteins can't change much)
Coilover springs are nearly all the same length unless you're getting custom length ones. Springs don't control the ride height on coilovers, they control the stiffness. They play a small part in ride height, but they're not the main benefactor.
I'm not saying this to make you feel dumb or something, I'm trying to explain why we're saying you need adjustable coilovers to get your car that low; it's just not something that can be done on the stock suspension
Cheap coilovers are used for nothing other than what your looking for, and the extra settings your talking about are compression/rebound adjustments (if that) which since you dont care about ride quality wont matter to you. Most likely this guy is on some type of coilovers, or cut spring which as stated above is a very bad idea. Go buy a set of ebay coilovers for $500 and youll achieve what you want, but at least youll be able to raise your car back up when you get tired of it having no functionality.
This car has the Bilstein BPS kit which looks like their entry level adjustable height C/o
The article notes he running the 20K/18k which sounds ridiculous & noted the ride is a bit harsh He's running this rate because he didnt want any fender rub
Stretched 235/40's
http://www.thirdworldsociety.com/shusevo/
Stretched 235/40's
Thanks for the info guys. It does seem crazy stiff what's he's running huh? I was gona stick to 10k/12k. I'll have to look for a decent set of coils, most likely around $1000+ then.
A high quality C/o that may fit your budget is something a lot of us run. Call Terry at FA & tell him what your doing w/your EVO & he will build you a set of FA500's
http://www.fortune-auto.com/
