Stacking Spacers?
Old Sep 6, 2016 | 09:21 AM
dave_evolvix's Avatar
Stacking Spacers?
I've recently made my bid to join the wide tire club, and enjoy the wide selection of 18" r-comps available. I wanted to go with the tried and true setup - RPF1s.
18x9.5 +38s, I'm going to run 255/35s and 265/35s R-Comps on the car.
I put ARP extended studs all around, and purchased some STM 20mm spacers for the front. From what I read, i figured this would be an ideal fitment. However the clearance for the front caliper is tiny. I'd say 1-2mm.
Now my first thought was to simply add a cheap 3mm spacer underneath my hubcentric 20mm spacers to give me the perfect fit up front. My goal is minimal fender modifications. Is stacking spacers a serious no-no?
What are my other options? 25mm spacers (any recommendations as I already installed studs)? Custom 23mm (from where)?
I don't have my tires yet, but when I get them mounted I'll be evaluating the rear trailing arm clearance, seems tight. Definitely the closest point. Might go with 5mm spacers in the rear.
Old Sep 6, 2016 | 10:55 AM
Running a spacer in itself, if not machined perfectly, adds another rotating part to the equation.
Stacking one on top of the other sounds like a bad idea
I would be inclined to run the larger 25mm single spacer. With spoke flex, that 1-2mm may not be enough
Old Sep 6, 2016 | 11:40 AM
Definitely not enough clearance...
Brembo recommends a minimum of 3mm clearance between the caliper and the wheel spoke or rim.
- http://www.nolimitmotorsport.com/bre...clearance.html
So what are the exact concerns for stacking? Increased risk of vibration? Cornering forces ending up at the wrong place?
Thoughts on JM Fab spacers? They have 23mm (built to order).
http://www.jmfabrications.com/store/...l-Spacers.html
Old Sep 6, 2016 | 12:02 PM
Running wheel spacers is really not a good thing to begin with. A proper wheel offset is always best
We have proven, in the EVO community, that running a less than 25mm spacer seems to work Ok but does add extra load to the hub bearing
Stacking just adds another element of potential issue of vibration due mis-machining & corrosion build-up over time
Sure you can try it, but its really not a sound wheel end system
Old Sep 6, 2016 | 12:10 PM
V.8MR's Avatar
The other issue with spacers is they change the scrub radius. Best to stay as close to stock offset from hub as possible to maintain correct geometry.
Old Sep 6, 2016 | 02:17 PM
Stock wheel size/offset (+30) and 224-245 r-comps just can't get the grip I need for a heavy car. So I've decided:
Grip > Scrub radius (within reason)
That being said I'm going with 23mm single spacers, so I should have 4-6mm caliper clearance which should be plenty for RPF1s.
I'm going to try and avoid putting 5mm spacers in the rear, see how the rear trailing arm situation turns out.
Old Sep 6, 2016 | 02:36 PM
V.8MR's Avatar
Enkeis are 17" x 8", 35mm offset
BBS are 17" x 8", 38mm offset
You want to run +38 with 23mm spacer which will net you a +15... People do it, I just want to be clear in what you are going to end up with.
Old Sep 11, 2016 | 09:01 AM
Raptord's Avatar
I always thought the vast majority of people with 18x9.5 +38 RPF1's ran 20mm spacers in the front without trouble; is it actually ~23mm that most people use with these wheels?
Old Sep 12, 2016 | 11:43 PM
Kritiang's Avatar
Same here
Old Sep 13, 2016 | 06:49 AM
meckert's Avatar
Take you spacers to a machine shop and have then cut 2mm off them--that way they are concentric and flat..
Old Sep 13, 2016 | 07:40 AM
GTijoejoe's Avatar
We typically target 3mm to guarantee clearance with wheel deflection under high loading
With stacking spacers your largest concern is maintaining the assembled runout of all the components. When you add more components your are adding more tolerance of the combined flatness of the assembly, essentially it will always give you more runout.
From a mechanical point of view, the more surfaces you have in a joint the higher risk for torque loss, usually there is more relaxation in a joint with more surfaces.
In terms to spacers and your suspension geometry:
Essentially it boils down to what choice of wheel width/size, offset spec you choose in the first place. A spacer is specifically reducing your wheel offset spec, its that simple.
So if it is down to a specific suspension geometry vs fitting a wheel spoke design to fit a brake package, you would need to choose a different wheel. However, there is always a limit
Old Sep 13, 2016 | 07:50 AM
RazorLab's Avatar
Motorsport Tech have made me a bunch of hub and wheel centric custom spacers and they have all been great. I highly recommend them!
Old Sep 13, 2016 | 01:27 PM
LetsGetThisDone's Avatar
x2. I have 2 sets of spacers from them; one for my track wheels and one for my street wheels. Great quality and pricing.
Old Sep 13, 2016 | 01:34 PM
heel2toe's Avatar
^x3 I too bought my spacers from them and they turned out great. They ended up being a couple mm's too large (my fault I didnt know exactly what size I needed) so I had a local machine shop turn them down for me.
But I would recommend them over other spacers given the fact that they are both hub centric and wheel centric. Most spacers are either/or.
Old Sep 13, 2016 | 01:56 PM
This is why I went with them. They are the only I've found that will a custom spacer your specs for thickness, hub size, and wheel bore size. And they don't cost an arm and a leg. A couple companies would do it, but, "oh, well, we'd have to change programming and redo the fixture, so it would be like an extra $100"....f#ck outta here.
