Does added caster change alignment?
Subscribe
May 8, 2017 | 06:40 PM
Had alignment done recently and was thinking about getting added caster from lower control arm offset bushings. Would you need a realignment if taking the lower control arms down?
Reply 0
May 8, 2017 | 07:57 PM
Pretty sure, changing caster will affect the other parameters. Cant change any of the front susp components w/out it affecting the other set points (toe,camber etc)
Moving the lower strut fwd, to achieve positive caster, has got to change at the very least toe
Reply 0
May 8, 2017 | 08:37 PM
I've been able to make camber adjustments without affecting toe, etc. But caster is a whole nuther story. I'd definitely get it checked.
Reply 0
May 8, 2017 | 09:24 PM
the only way to know is to check
Reply 0
May 8, 2017 | 09:56 PM
Quote: I've been able to make camber adjustments without affecting toe, etc. But caster is a whole nuther story. I'd definitely get it checked.
Changing camber definitely changes toe. Changing caster has a marginal effect on toe, depends where you are in the bump steer curve. Adding caster has a much bigger effect on bump steer than lowering the car.
Reply 0
May 8, 2017 | 10:30 PM
Quote: Changing camber definitely changes toe. Changing caster has a marginal effect on toe, depends where you are in the bump steer curve. Adding caster has a much bigger effect on bump steer than lowering the car.
We measured and didn't see movement, so I dunno.
Reply 0
May 8, 2017 | 10:52 PM
Quote: We measured and didn't see movement, so I dunno.
Must've measured wrong, sorry. Camber def hanged toe. It changes the distance between the steering arm and the rack.
Reply 0
May 9, 2017 | 01:03 AM
Quote: Must've measured wrong, sorry. Camber def hanged toe. It changes the distance between the steering arm and the rack.
I suppose the alignment machine coulda been off. I dunno but it sure is nice driving around with normal camber in the front. Tires last a lot longer.
Reply 0
Subscribe
