Konig Hypergram Question
Old May 12, 2018 | 05:34 PM
SW20Mike's Avatar
Veteran: Air Force
So, just pushed forward with getting ARP extended wheel studs on the front. Figure its cheap insurance for less than $70, give me peace of mind.
Old Jun 19, 2018 | 06:06 AM
MP Evo's Avatar
I see he went with 18x8.5 +35 so im going to assume a 17x9+25 would fit.
was wondering if the orignal poster can take some side angled shots like to see if they concave or what they do at a 8.5 wide wheel
Old Jun 19, 2018 | 05:36 PM
SW20Mike's Avatar
Veteran: Air Force
not sure if photos help, but here you go.
Old Jun 21, 2018 | 08:35 PM
MP Evo's Avatar
thats the 18x8.5 +35 right? They look still sunk in. Figure they would be flush
Old Aug 15, 2018 | 09:21 AM
SW20Mike's Avatar
Veteran: Air Force
Pictures are hard to make out, but in person they are relatively flush. Now that I've got ARP extended studs up front, I suppose I could go up from the 5mm spacer to push the wheel out more. I'm still on the stock rear studs, so maybe in the future I'll replace those as well and go 10mm spacers all around. As is, I'm happy. I just wanted lighter wheels that I liked visually for under $1K, these wheels definitely accomplished that. If you want a more aggressive stance, the specs I got are probably not the way to go.
Old Jan 17, 2019 | 04:10 PM
Crankwalker's Avatar
Then run a 10mm spacer in the front . You'll need to anyways for a 265/35r18 to clear the strut with a 35 offset wheel.
Are you positive a 18x9.5 +35 with 265/35s will need a spacer to clear the suspension?
Old Jan 18, 2019 | 07:12 AM
MP Evo's Avatar
I'm running 18x9.5 +25 with 255/35 tires. Clears suspension but does have slight poke. -1 camber on all corners.
Old Jan 20, 2019 | 03:52 AM
Looks awesome man! Did you have to roll the rears any? Think 265s would be hard to clear?
Old Jan 21, 2019 | 08:53 AM
MP Evo's Avatar
I'm not slammed so i get away without a roll but it sometimes rubs on the left rear depending on the road. With that being said i might do a slight roll but nothing crazy a 265 tire depending on the tire probably will need a roll im going to guess because it pokes on my car so you wouldn't have any stretch in the tire.
2wdSQL
Aug 9, 2004 07:05 AM
CivicEater
Northwest Region
Oct 19, 2002 09:02 AM
cnile51
11
May 22, 2002 02:23 AM
