Coil overs
Old Aug 9, 2019 | 12:28 PM
  #166
RazorLab's Avatar
Originally Posted by EvoJoe21
I may just pull the trigger on the NT03s - seems like they’re light enough for track duty and strong enough to keep my mind at peace. I should probably start another thread lol sorry OP
I've beat the heck out of both sets of NT03's I have on my 10 with zero issues. If you like the style, then they are a great cost + performance ratio wheel.
I'm def not shy with curbing on track.
As far as spacers, I think most people that are anti-spacers haven't run them correctly. They either use the wrong studs, buy cheap crap or don't understand physics and engineering.
Old Aug 9, 2019 | 01:23 PM
  #167
CDrinkH2O's Avatar
For Sale Ohlins R/T 8/10k $1950!
https://www.evolutionm.net/forums/market/754944
Old Aug 9, 2019 | 02:47 PM
  #168
EvoJoe21's Avatar
That is reassuring. I most definitely enjoy the NT03 style so it looks like we have a winner.
Looks like the PO was running some shoddy spacers anyways so I’m opting for ARP studs with a new spacer. I’m getting a slight squeak from the front driver side and I’m pretty sure it’s the wheel bearing 👎
I ended up going with the 8k/10k rates as they are not currently on back order - that being said I’m happier to have the 10k rears to start with without totally overblowing my entry level setup.
Old Aug 9, 2019 | 02:50 PM
  #169
EvoJoe21's Avatar
Originally Posted by cdrinkh2o
Thanks man I’ve been eyeing these! But there’s something about “new” that gives me the Christmas morning feel that is needed sometimes. GLWS 👍👍
Old Aug 9, 2019 | 09:29 PM
  #170
kaj's Avatar
kaj
You will be stoked with the 8/10. If getting spacers, just be sure to get a set that is hub centric and use hub centric rings for your wheels. That should take care of wobbles and vibration.
Old Aug 10, 2019 | 09:08 AM
  #171
EvoJoe21's Avatar
Ok cool thanks for the support! Now it’s off to my timing belt/water pump change (60k service) and I’m totally dreading 😞. If anyone is in Orange County and has done a few of these let me know! It’s pretty much the last thing on earth that I want to mess up right now.
Old Aug 10, 2019 | 12:44 PM
  #172
kaj's Avatar
kaj
I'd suggest investing in timing belt tools. They make the job 10000000x easier and I can't imagine adjusting the mechanical tensioner without them. You will want the tool for that, the one that holds the cam gears still is a HUGE help. The one that compresses the hydraulic tensioner is really only essential for work where you're not replacing it. New hydro tensioner = no need for that tool.
Old Aug 10, 2019 | 09:08 PM
  #173
yip's Avatar
yip
I spoke with Jayme at PSI this morning and Ohlins are on back order for another 4 weeks unless I go with 8k/10k - not sure if I wanna go lower than 9k in the front. Anyways, I have time to shop around for wheels if I wait for the 9k setup...thoughts?
4 weeks is nothing. I recommend waiting since there is no draw back going with 12k/14k.
Old Aug 11, 2019 | 10:01 PM
  #174
EvoJoe21's Avatar
thanks for the tip! I’m going to dive into this thing as soon as the parts come in and see what happens. Pretty confident since I have skinny arms and long fingers lol.
