Coil overs
Old Jan 9, 2019 | 05:53 AM
  #106
Originally Posted by kaj
If unanimous testimony and lap times aren't enough...then yeah. I guess facts are good too.
At the same time ,if all we had were facts and charts then everyone would be like, "yeah, but I want to hear from people with real-world experience".
So ,either way ,I guess..?
Youre right Jason. Opinions can be formed by lap times, service performance, available options, customer support & product longevity. (among other things)
IIRC, in 2017, the quickest car around Buttonwillow was our RS Motors car w/Stance coilovers (Yes, STANCE)
Old Jan 9, 2019 | 07:11 AM
  #107
Crankwalker's Avatar
Originally Posted by dookgvr4
I found found my self in the same position regarding the same decision.
I also feel after quite a bit of reading on the topic that an often overlooked coil over in this category is the HKS Hipermax.
The HKS comes in two varieties as well (gt/sp) and the fronts are inverted like the ohlins. If shopping around both varieties of HKS can be had for under 1,500 shipped.
I picked up the FA 500 with swift 8/10 on Black Friday for a really good price. I was under impression that radial bearings were included but they were not. (Trying to sort out with vendor). But now I wonder if I should have purchased the HKS
Here's a pic of said FA's
They were an upgrade on the Gen 6's, now they come standard... Get them installed! I'd like to hear your feedback
Old Jan 9, 2019 | 08:16 AM
  #108
Dallas J's Avatar
Veteran: Army
Lap times are certainly a metric but one that relies on way to many factors here. I would even argue, somewhere around 98-99% of the performance on a perfect road course lap time could be done with complete **** shocks setup well and driven around any odd flaws like complete f/r miss-match damping ratios.
Reason I say this, you spend most of your time on track in steady state and a perfect lap wouldn't need significant midcorner adjustments or controlling out of ordinary behavior like hitting a curb too hard, dodging another car, etc. The shock isnt going to change your maximum lateral grip, and in transition even a crap shock is going to provide some amount of damping. It might be way to little or too much, too harsh or too slow. But these are things drivers just figure out how to drive around.
To me, a lot of the magic of a good shock is being able to control the wheels or rate of roll in a way that's more unobtrusive. I don't want the shock to make the car feel artificially stiffer like the Evo oem shocks did (not the bilsteins, the GSR shocks) or the current FocusRS shocks. Or wallow around like a chevy SUV that seems to respond to a bump for days after its hit it. This is going to help in areas of heavy transition (AX, rally, etc), immediate need (like dodging something), or ride comfort.
The DFV is a great balance here on the variable even if its not perfect for top level racing. It might just be a happy accident that even though they have the spring balance wrong, the valving balance between compression and rebound in their dual adjusters are suited well to the Evo's distribution of weight and motion ratio. The dropping of compression seems to work well with the rebound as things are adjusted to make it comfortable on the street and adequately controlled on the track. You will still get to a point where more rebound or less compression is needed but you cant add one without the other. At that point you really need a fixed compression for the spring rate or double adjustable.
I would certainly put money on a custom set of Stance or FA or whoever over DFV when it comes to high spring rate setups. But they arent going to also likely be street friendly. If I were to put my money where my mouth is, 100% DFV on any car that sees >50% street use. Once you hit mostly track, I would be more critical on the guy building my shocks, their experiences and wins, and what he can recommend. Right now I think the guy I would call would be Guy Ankeny.
Old Jan 9, 2019 | 09:34 AM
  #109
Well said there Dallas.
Just so those that maybe interested in FA C/O'r, their valving has a name as well (Ultra Digressive Piston).
In laymans terms, the valve blows-off during hard hits (potholes, track curbs etc) & then returns to normal valving.
I used to run the curbs at my local track & w/the Digressive system, you can really feel the valve blow-off when running the curbs (not harsh at all but a super smooth absorption of the curb contact)
Heres their marketing pitch on the valve (PA EvO is in the Vid)
Old Jan 9, 2019 | 09:41 AM
  #110
Wanted EVO IX's Avatar
Very well said,
Also want to add that the money savings you would get with the HKS/FA could be put to use in areas that will matter as much to your overall performance and experience. Coilovers are not the end all solution. Once you make up your mind on a certain product, you will need to invest in ( setup, alignment, tires, bushings ) etc. This will maximize your experience. I know because I've had to do this already. Since doing the install of my FA's I think I've had 4-6 custom alignments, $$$ could have spent that on another set of tires.
When I got my FA's I slapped them on the Evo not knowing anything about setup and didn't pay much attention to what was required to get the most out of the product. I hated the car as it would not do what I needed it to do. I was fighting it in autocross, I was slower than I was with my stock shocks with Hotchkis lower springs. I went backwards to go forwards. I thought I had made a big mistake but it was all my fault, I had no clue on setup and or how to use the coilovers. I remember once I installed them, like a rookie I cranked everything to full stiff. I was a fool, over the course of trying new ride heights along with backing off from full stiff to where I am now. I'm close to full soft. I love how my car feels now and I have room to go to get the most out of my setup. We have an upcoming autocorss and I'm considering raising my front ride height half inch as I need to rotate the tires to get more out of my setup.
Old Jan 9, 2019 | 10:05 AM
  #111
kaj's Avatar
kaj
I think I remember that But yeah.. that's why I was saying any decent coilover can be tuned to work well on a road course. Dallas went into more detail with it:
I was just too lazy to type all that Anyone else have issues typing on the phone app? Like every other word is autocorrected wrong and the spelling gets all whacked when you try to correct it. LOL.
Old Jan 9, 2019 | 10:06 AM
  #112
Dallas J's Avatar
Veteran: Army
Im here for you bro!
Old Jan 9, 2019 | 10:38 AM
  #113
kaj's Avatar
kaj
And I forgot to say "thank you". Details on Guy Ankeny?
Old Jan 9, 2019 | 10:43 AM
  #114
Dallas J's Avatar
Veteran: Army
https://www.facebook.com/Ankeny-Raci...3734168656554/
He's been in the game a long time building custom shock setups.
Old Feb 20, 2019 | 11:50 AM
  #115
Well guys, I finally bought coilovers! And while my wallet is crying, I was just wanting to double check that I can (with stock valving) and if I should swap the front and rear springs on the Ohlins...
Old Feb 20, 2019 | 12:21 PM
  #116
kaj's Avatar
kaj
As long at the they are within 2k of each other (I assume valving can handle +/-2k), should be fine, I'd think. Hopefully someone who knows for sure can chime in.
Old Feb 20, 2019 | 01:46 PM
  #117
I just ordered them as they come. So the rates are 10k Front 8k rear. But I know many people run the opposite, plus I was just wondering if the 10k would be too much in the rear with a 26mm RSB...
Old Feb 20, 2019 | 02:49 PM
  #118
Dallas J's Avatar
Veteran: Army
26mm is a lot of bar for only 10k rear. That ends up being almost 60% of your total roll rate in the rear is from the bar alone. I'll caveat that with, from the factory the front is 50% and the rear is 60%, but those are also much lower rates and these car are pretty heavily dampened low speed from the factory.
I would be looking to run something in the 22-24mm on the 10k rear springs. I run the same bar, but double the spring rate.
Old Feb 20, 2019 | 03:19 PM
  #119
kaj's Avatar
kaj
I'm running 10k rear with a 25 mm bar on second from soft. Feels pretty decent. Hmm..
Old Feb 20, 2019 | 07:19 PM
  #120
I had initially planned on just getting a 24-25mm bar and this past Christmas the wife gave me the whiteline 26mm RSB, I wasn't about to tell her she bought me the wrong parts!😆 So that's how I ended up with the BIG bar!
Do you think running the Ohlins at 8k Front 10k Rear Will be okay?
I've read the out of the box set up works really well after you swap the springs, so I didn't think there would be any need to up the rates and revalve...
