Abs wheel sensor reading error
Old Jan 18, 2020 | 04:44 AM
Mohsin Abbas's Avatar
Hey guys hope you are doing well
i own a mitusbishi evolution 6 i m going through a abs fault...but no abs light on the dash neither any error if i check with a scanner the issue is with the rear right speed sensor which read the twice of the speed the rest 3 of the wheels read same speed i am not sure if this is the fault anybody can help me out so please reply
thanks in advance
Old Jan 18, 2020 | 07:00 AM
@Mohsin Abbas What kind of scanner did you check with? If it was a standard OBII, dont think that will pickup ABS issues
I thought a dedicated Mitsubishi type scanner must be sued to detect the ABS code?
Old Jan 18, 2020 | 02:57 PM
i am checking it with launch x431 pro
Old Feb 22, 2020 | 01:04 PM
barneyb's Avatar
Jumper the signal to the wiring of the opposite hub. If the problem moves its in the hub, if not, up front.
Dangerdave
Jun 4, 2015 06:56 PM
HiRevnVIII
Mar 1, 2010 05:58 AM
Dboey
Dec 27, 2009 06:10 AM
Driveteam
Mar 31, 2009 06:42 PM
