Rota Grid question
Old Jun 1, 2020 | 06:15 PM
everkain's Avatar
Rota Grid question
Hey everyone,
just a quick question about fitment. I'm looking at a set of rota grid's in 18x9.5 20mm offset. Can i run these on a stock strut w/ swift spring without rolling the fenders? any brake clearance issues? I know i could search, but forums are like a dying art so might as well try to get some convo going. thanks in advance
Old Jun 1, 2020 | 06:33 PM
Not quite sure on the caliper fit, but ROTA's have traditionally been very caliper friendly, especially in a +20 offset. (more than likely it would fit w/a spacer)
The biggest concern is the 9.5" coupled w/the +20. Certainly dont recommend it as it would take all the rear fender tricks to make it close to working. Fender rolling would be the very least of the mods required
Old Jun 1, 2020 | 06:41 PM
everkain's Avatar
Thanks. I read your responses in another thread. you def know what you're talking about. Should i look for maybe a 8.5 wide to fit without having to do all the fender magic? I'm guessing the width is the issue. I'm not looking to go crazy, otherwise i'd be talking about te37's and not rota's. haha.
Old Jun 1, 2020 | 07:02 PM
Dont knock the ROTA's haha. I have a set i run on the street (P45R's 17x9.5 +30 running some 275/40's)
Its the +20 that makes that wheel tough & the 9.5" width. If youre looking for the least amount of rear fender work,
look at some like this:
  • 18 x 9 +32 to +35
  • 18 x 9.5 +35 to +38
Something in that range would be a good starting point IMHO
Old Jun 1, 2020 | 07:15 PM
everkain's Avatar
  • 18 x 9 +32 to +35
haha. yeah. i used to run a set of sub zero's on my 05 sti back in 2005. they were great for what they were. So would i be right in assuming that i'd lose most of the concavity going with a +35? So for evo 8/9, if i wanted to not touch the fenders, keep the offset above +30? did you have any issues with your 17x9's?
Old Jun 2, 2020 | 05:47 PM
I say to keep the tire off of the rear fender, a +35 or higher is needed. You really need to have the rear fenders treated if you want to run the wide wheels & tires. My 17 x 9's have 275's strapped to them so for sure my rears have had all the fender work required
Old Jun 4, 2020 | 06:30 PM
everkain's Avatar
Hey Minus, do you think a 17'x9 +35 enkei kojin w/ 255's will fit without fender work? if so, do you think they'll poke out the fender? thanks
Old Jun 4, 2020 | 06:43 PM
That is an excellent choice in wheel size. The 255/40's will look very meaty on them. As far as clearance its going to be very close to needing a rear roll. If you run some aggressive rear camber (approx -1.8 degrees) that may get them to fit.
Bottom line is, you really need to think about getting the rears rolled!
Old Jun 4, 2020 | 06:47 PM
everkain's Avatar
HAHA. yeah, i want to down the road. The thing is, the car is on jack stands since i'm in the process of rebuilding the engine and trans. So unfortunately, I can't take it anywhere to get them rolled. I can always run the stock setup and keep these in the garage and when its up and running, then i can go and have them rolled. thanks for all the help.
Old Jun 4, 2020 | 06:50 PM
Forgot to answer your question regarding poke. They will definitely not poke outside the fender. Even a +30 doesnt poke & is just getting to a flush fit w/the rear
fabcas311
15
Mar 25, 2014 10:10 AM
VWJETTY
Jan 24, 2014 06:12 AM
FlatWhite_Evo
Jul 14, 2011 01:24 PM
FmFracing63
13
Jan 24, 2010 11:38 PM
4g64Lancer
Apr 13, 2003 02:12 PM
