Making a mistake by installing a staggered wheel setup on my 8?
Old Dec 1, 2025 | 06:45 PM
NOMIEZVR4's Avatar
Have the option to buy 18x9.5 and 18x10.5 wheels for my evo 8. +30 offset. I understand that if the rolling diameter is kept the same, or <1% difference F/R its a non-issue and wont damage the tcase and/or diffs. I have a stock body evolution. Stock fenders other than they are rolled.
Yes, I understand the rear will require some massaging to fit, my fenders are already rolled as well as extended studs already. Fronts I have wilwood calipers. The car is strictly a street car and will likely never see the track under my ownership.
With that being said, is it a bad idea to get a staggered wheel setup for aesthetics? I think a wide meaty tire would look cool. The car wont be driven enough to warrant rotations, so I'm not concerned about that. Option 2 is: should I stick to the typical tried and true safe 18x9.5 setup?
wheels in question are NT03's and I would probably size the tires out 245/40 and 285/35
Old Dec 2, 2025 | 06:07 AM
schuhie's Avatar
I personally wouldn't run a staggered setup. You are correct that if the rolling diameter is kept close it won't cause issues but I think you are going to have a hard enough time getting the 9.5s to fit in the rear as it is.
To me, the look isn't worth the hassle of different size wheels.
Old Dec 2, 2025 | 07:29 PM
NOMIEZVR4's Avatar
Yeah i passed on the set. Thanks
.DoT.
10
May 17, 2016 10:25 AM
EvoXboy
Mar 7, 2015 07:40 AM
DaJackson
35
Jul 29, 2010 07:51 AM
eyekyu
19
Mar 22, 2009 01:53 PM
