Hallman PRO Kit MBC
Hallman PRO Kit MBC
How do you replace the spring with the Hard Spring?
It came with the instructions but it doesn't have the spring installation or removal
Oh, how high can you boost with a HKS Dowpipe, HKS Hi Power Cat Back and an AEM Intake? via 91 pump gas?
Can it handle 22psi of Boost?
Any info is greatly appreciated.
Thanks...
Thanks...
The caps doesn't come off. The bottom does. You unscrew the cap to the end then unscrew the bottom of the MBC and the spring and ball will come out. Replace the spring the same way it came out and HAND tighten the thing back together.
So do you think without the Fuel Pump and Dynoflash I can run 21psi too?
Here are my current mods
HKS Dowpipe, HKS Hi Power Cat Back and an AEM Intake gonna be using 91 Pump gas.
Is 21psi too high for that kind of mods without the Dynoflash and Walboro 255 pump?
I'm already using the soft spring that came pre installed, and its already turned all the way clockwise, Im getting steady boost of 20psi to redline, sometimes tapering down to 19.5psi
Oh anybody noticed the fast spool up? It seems to spool up faster now.
DarkEvo
Jun 9, 2012 05:58 AM
zzombae
33
Dec 8, 2009 11:36 PM
forum04pl
Apr 7, 2004 08:23 PM
