Tein H-Techs
Old Jun 22, 2004 | 11:13 PM
Tak555's Avatar
Tein H-Techs
A search did very little in answering my questions...
These springs seem to be a good compromise... not too stiff, not too low. but i've heard that they are actually softer than the stock springs. is this the case? according to the spring rate chart on this site, that's not true.....
who has first hand experience with these? pros? cons?
any info is much appreciated...
greg
Old Jun 23, 2004 | 12:08 AM
Corey's Avatar
The H-Tech's have a stiffer spring rate than stock. They are just not as low as the S-Tech's. If I was buying another set of springs I'd buy the H-Tech's over the S-Tech's anyday.
I'm gonna hold out til fall and take my Volks off, put my stock wheels on, and raise my car up. I'm gonna use the winter to save for some coilovers.
Old Jun 23, 2004 | 04:28 PM
Tak555's Avatar
i'm assuming you have the s-techs on right now....?
imo, yeah, the stechs lower the car too much. but are the h-techs too soft for the amount they lower the car? will i still be hitting the bump stops?
Old Jun 24, 2004 | 08:48 AM
stEVOVIII's Avatar
i recently bought the tein s-techs and ther are amzing! stiff and a lower ride for your evo
Old Jun 24, 2004 | 08:53 AM
chinalfr's Avatar
Search the forum for spring rate and you'll find all the info you need about spings/coilover.
For lazy bum, here is the link https://www.evolutionm.net/forums/sh...ht=spring+rate
I have H-tech on my ride for about a months. Highly recommended. The ride is comparable to stock but with a nice lower ride.
Old Jun 24, 2004 | 12:39 PM
Corey's Avatar
The H-Tech's are stiffer than the stock springs. Just as long as you trim the bump stop like it says you should be okay.
Old Jun 24, 2004 | 12:42 PM
Invoice EVO's Avatar
Veteran: Air Force
My thoughts exactly.
Old Jun 24, 2004 | 01:16 PM
Tak555's Avatar
sweet, yeah, i just want the car to be a bit lower, so it sounds like the htechs are a good compromise... i'm suprised, most of the springs out there dump the car dramatically.
GTWORX.com
EvoX 'For Sale' Suspension / Brakes / Handling
55
Nov 21, 2011 10:22 AM
Lance888
Sep 27, 2008 04:08 PM
EvolNinja
Aug 2, 2008 07:31 AM
mirage 4g93t
Apr 7, 2008 07:33 AM
Derek888
15
Apr 30, 2005 10:24 PM
