Evo X Red tuned on E85 @ AMS!!
Old Sep 14, 2009 | 07:15 AM
  #46
Chris@AMS's Avatar
FWIW, this is actually what FP Red's make on this dyno. Despite constant rumors of 'dynojet correction factors', for some reason, our dyno reads very consistently and the power output actually matches the flow 'ability' of the turbo combination. I've tuned 15-20 fp reds and this is REALLY what they make...
Old Sep 14, 2009 | 07:47 AM
  #47
Sean@Iveytune's Avatar
I concur the numbers look just like what we make here with the RED on the evo 10.
Sean
Old Sep 14, 2009 | 10:11 AM
  #48
GST Motorsports's Avatar
I'll 3rd that.
- Bryan
Old Sep 14, 2009 | 10:40 AM
  #49
LOL Bryan!
Sean
Old Sep 14, 2009 | 10:47 AM
  #50
murlo26's Avatar
Have any of you guys noticed that the Blouch's flow any more, the dom2's?
The two turbos seem to be very comparable and DG Motors seem to think they flow a little more?
Any comments on that
Old Sep 14, 2009 | 10:52 AM
  #51
Tractionlimit's Avatar
Originally Posted by aftershock141
I don't know why but after reading this thread I am kind of disappointed; especially with seeing people making ~400whp with meth on the stock turbo, or 430+ on the red with 93 octane. Do you know if this was a pretty conservative tune or what? I would like to see what you trap with some actual traction.
Sorry to hear you're disappointed, but nobody who has ridden with me seems to share that feeling. Most people have mentioned the nice compromise between insane power and quick spool-up. It is still a stock-frame turbo, afterall. I'll post an updated slip, though, once the car is done.
Old Sep 15, 2009 | 09:42 AM
  #52
soyboy26's Avatar
good numbers
Old Sep 16, 2009 | 09:06 AM
  #53
Chris@AMS's Avatar
Sean
Originally Posted by GST Motorsports
I'll 3rd that.
- Bryan
Thanks guys
Old Sep 18, 2009 | 07:31 AM
  #54
hlm's Avatar
hlm
Nice numbers!!! Be interesting to see what I end up doing to our EVOX shop car!! Nice to see your from WI what drag strip do you go to??
Old Sep 22, 2009 | 01:29 AM
  #55
KIDBANGA10's Avatar
subscribed...nice numbers
Old Nov 12, 2009 | 09:50 PM
  #56
Went back to AMS for some tweaks and to make the switch from manual boost control to ECU boost control. So far I'm very happy with the results. Driveability has improved and the car is smoother and more civil at part throttle and on/off transitions. I just have to remember now to keep my foot to the floor to stay at peak boost, but I think that's how it should be . The car holds a bit more boost to redline and also picked up a few HP while there, which never hurts . THANKS AGAIN, AMS!!
481WHP and 443TQ uncorrected (471/434 SAE) @ 31PSI Daily Driver
Old Nov 12, 2009 | 10:09 PM
  #57
flyguycfi's Avatar
Sick numbers! Makes me wish we had E85 available down here in FL.
Old Nov 12, 2009 | 10:46 PM
  #58
Clark_Kent's Avatar
Same here. It's available here but the pump closest to me is too far away to make it feasible. Good work AMS.
Old Nov 12, 2009 | 10:56 PM
  #59
BLKCarbonEVO's Avatar
Chris, sorry for my dumb question but can the X Reds just not be pushed over 30psi like the IXs or are there limitation with the Stock computer holding you back? Also do you think the 12cm housing help the turbo from falling off as hard as the 10.5cm housing on the IXs? Thanks
Mikey
Old Nov 13, 2009 | 12:21 AM
  #60
Hiboost's Avatar
Nice setup that seems to be in the 575 crank HP range based on what I've seen the AMS DynoJet convert to. That should be good for low 11's maybe even high 10's with the right launch at 125-126 mph. That is also assuming you can rev out 4th gear in the quarter, the final drive upgrade is going to be a necessary component for most people without building the engine to allow 9k rpm's.
Hopefully I can manage similar numbers or even hit 500 whp on a dynojet with Cams, race gas, and higher boost.
