Dom2 + E85 + BlaqOps = 452whp
Old Nov 17, 2009, 03:05 PM
DG Motors's Avatar
Originally Posted by GST Motorsports
No problem. I'm all for sharing info, but I just think different vendor/dyno plots in another vendor/dyno plots thread like that can be a recipe for confusion.
- Bryan
Understood.
Old Nov 17, 2009, 03:18 PM
Evo a Mula's Avatar
How is that double pumper working are you anywear near maxing it out?
Old Nov 17, 2009, 03:23 PM
DG Motors's Avatar
12.4 to 9.6 @ 50 base seems like It is doing It's job rather well!
Old Nov 18, 2009, 07:50 AM
t12ung's Avatar
Yeah I am no where close to maxing on BLAQOPS's double pumper system. I think Bryan concluded that I have enough fuel delivery to run a gt35r no problem. I love it because its so quiet and you don't get a whine like the external inline pumps.
Old Nov 18, 2009, 07:51 AM
murlo26's Avatar
You have the one based on the MAF signal right?
Old Nov 18, 2009, 07:54 AM
t12ung's Avatar
No I used boost controlled.
Old Nov 18, 2009, 08:00 AM
murlo26's Avatar
So there is a progressive boost controlled one and progressive MAF signal one?
So this isn't just the hobb's switch one is it? Where at X amount of boost the second guy kicks on.
Old Nov 18, 2009, 08:04 AM
murlo26's Avatar
Nevermind, I didn't realize that the progressive controllers use either boost of MAF signal. Answered my own question, i checked their website again.
Old Nov 18, 2009, 08:21 AM
DG Motors's Avatar
That's great, the 044 pumps we have been using are quite noisy which is impossible to hide unless you have a real loud exhaust.
Can't really be too stealthy with an external pump that whines like a dying goose.
Old Nov 18, 2009, 08:35 AM
Evo a Mula's Avatar
yeah thoes external pumps are loud...w/e thoe ill just turn the radio up lol
Old Nov 18, 2009, 09:33 AM
Hiboost's Avatar
Nice results and powerband here! Hopefully I can get something similar on race gas and my GT30.
Old Nov 18, 2009, 09:35 AM
GST Motorsports's Avatar
Yes boost or MAF signal, this Evo has the Boost reference. It will progressively come on with boost. You select a initial starting boost and a full tilt boost level. The pump will smoothly come into full flow at the starting PSI and into the full flow PSI.
Think of it as a meth controller for your fuel system.
- Bryan
Old Nov 18, 2009, 09:37 AM
The one Evo 10 GT30 (after the first one blew up and took out the downpipe) on our dyno made 393whp on 116 oct at 28psi. 350whp on 91 oct at 24psi.
- Bryan
Old Nov 18, 2009, 09:48 AM
Hiboost's Avatar
- Bryan
Hmm that's interesting as a comparison, I'm pretty sure I can beat that but we will see. Based on VDR dyno comparisons I'm already up 20-30 whp from when I was dynoed last at 385 whp on STM's Mustang Dyno @ 27 psi (dyno reads similar to yours). I'm hoping to see solid gains from my modified intake manifold and Cosworth MX1 cams running about 30-32 psi on race gas. Likely the boost will make the biggest difference in the low to mid range where as generous timing advance will have to make up for the boost falloff above ~7400 to raise the peak HP numbers.
Either way that Dom2/E85 combo is about as good as you can get on a stock framed turbo setup and something to shoot for!
Old Nov 18, 2009, 10:13 AM
I hope you have better luck with the turbo. It just wasn't showing much gains past 28psi for me but you will have cams.
- Bryan
Quick Reply: Dom2 + E85 + BlaqOps = 452whp
